Home > Technical (L322) > knocking from the front offside (rumbling noise)
Monty1
England 2005 Range Rover Supercharged 4.2 SC V8 Rimini Red
ive just got back home after 17 days away and mrs monty collected the car after the gearbox rebuild, she had a concern about a knocking rumbling noise on the front offside, ive had the wheels balanced and tyres checked and all is ok.
theres a definet knock, and when going round a right hand bend it gives a strange rumbling knocking sound that i can feel under the floor of the car and through the steering, it doesnt happen when turning left.
i wonder it this has anything to do with having the gearbox refitted
tia tony
Post #179762 26th Mar 2013 5:20pm
More likely a worn CV joint.
Post #179764 26th Mar 2013 5:42pm
ebajema
Definitely sounds suspension related but. Has your car had the front diff modification done ? MY 2010 5.0 SC Galway green and sand interior!!
Post #179765 26th Mar 2013 5:59pm
Monty1
Front diff been done on the recall, this has only appeared after the gearbox rebuild, how do you test the cv joints
Tia. Tony
Post #179769 26th Mar 2013 6:13pm
Drive slowly on full lock in each direction.
You should get a distinct continuous knock on one side.
Post #179772 26th Mar 2013 6:21pm
Monty1
Been and tried lock to lock no knocking going left or right, the feeling on sweeping right corners is like a badly balanced tyre which gives a shake through the steering wheel and knocking on the floor under my feet
Tony
Post #179781 26th Mar 2013 6:57pm
Be worth checking for a worn wheel bearing.
Jack the wheel off the ground about 30mm.
Grasp the wheel top and bottom and try and move the top and bottom of the wheel in and out.
Grasp the wheel at the 3 and 9 o'clock positions and try and move the sides the wheel in and out.
There should only be nominal slackness, if any at all.
Post #179787 26th Mar 2013 7:13pm
Monty1
well ive changed the arb drop links which seems to have removed a lot of the knocking, but the rumbling problem when turning right is still there, wonerdering if it may be a ball joint ?
time to take it to a garage me thinks
tony
Post #179910 27th Mar 2013 12:53pm
Monty1
just a quick update, it was the near side track rod end, fitted a new one and theres no knocking at all Thumbs Up , its strange how it felt like the off side
Post #180583 31st Mar 2013 3:33pm
RRBlue
England 2005 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Monty1,
I have something similar but it is intermittent and almost feels as the car is touching the wheels. It only happens when turning right and not on full loock. It feels as though the car suddenly dtops at the front nearside corner.
I have had no clues or any signs in any other way.
Post #180679 1st Apr 2013 11:26am
Excellent cheap fix.... There is nothing that can't be fixed with a hammer😜😜
Post #180681 1st Apr 2013 11:41am
RRBlue
I will check the track rod end when I do the service this week.
Post #180684 1st Apr 2013 12:27pm
Monty1
I found my problem by moving the steering wheel quickly left and right whilst parked, it gave a clunking noise.
id advise changing the arb drop links, it makes such a difference to the cars handling and ride.
mrs monty commented on how much better it was Thumbs Up
Post #180807 1st Apr 2013 8:36pm
RRBlue
Is that the stabilizer link?
Post #180811 1st Apr 2013 8:52pm
Monty1
That's them, cost 30 quid for both and half a hour to change
Post #180891 2nd Apr 2013 12:10pm
