Home > Technical (L322) > knocking from the front offside (rumbling noise) |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3964 |
More likely a worn CV joint. |
26th Mar 2013 5:42pm |
Definitely sounds suspension related but. Has your car had the front diff modification done ? MY 2010 5.0 SC Galway green and sand interior!!
26th Mar 2013 5:59pm |
Monty1 Member Since: 07 Oct 2012 Location: Middlesbrough Posts: 181 |
Front diff been done on the recall, this has only appeared after the gearbox rebuild, how do you test the cv joints
26th Mar 2013 6:13pm |
Drive slowly on full lock in each direction.
26th Mar 2013 6:21pm |
Been and tried lock to lock no knocking going left or right, the feeling on sweeping right corners is like a badly balanced tyre which gives a shake through the steering wheel and knocking on the floor under my feet
26th Mar 2013 6:57pm |
Be worth checking for a worn wheel bearing.
26th Mar 2013 7:13pm |
well ive changed the arb drop links which seems to have removed a lot of the knocking, but the rumbling problem when turning right is still there, wonerdering if it may be a ball joint ?
27th Mar 2013 12:53pm |
just a quick update, it was the near side track rod end, fitted a new one and theres no knocking at all , its strange how it felt like the off side |
31st Mar 2013 3:33pm |
RRBlue Member Since: 24 Feb 2012 Location: Cambs Posts: 220 |
Monty1,
1st Apr 2013 11:26am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8486 |
Excellent cheap fix.... There is nothing that can't be fixed with a hammer😜😜
1st Apr 2013 11:41am |
I will check the track rod end when I do the service this week. |
1st Apr 2013 12:27pm |
I found my problem by moving the steering wheel quickly left and right whilst parked, it gave a clunking noise.
1st Apr 2013 8:36pm |
Is that the stabilizer link? |
1st Apr 2013 8:52pm |
That's them, cost 30 quid for both and half a hour to change |
2nd Apr 2013 12:10pm |
