![]() | Home > Technical (L322) > knocking from the front offside (rumbling noise) |
More likely a worn CV joint. |
Definitely sounds suspension related but. Has your car had the front diff modification done ? MY 2010 5.0 SC Galway green and sand interior!!
Monty1 Member Since: 07 Oct 2012 Location: Middlesbrough Posts: 181 ![]() ![]() ![]() |
Front diff been done on the recall, this has only appeared after the gearbox rebuild, how do you test the cv joints
Drive slowly on full lock in each direction.
Been and tried lock to lock no knocking going left or right, the feeling on sweeping right corners is like a badly balanced tyre which gives a shake through the steering wheel and knocking on the floor under my feet
Be worth checking for a worn wheel bearing.
well ive changed the arb drop links which seems to have removed a lot of the knocking, but the rumbling problem when turning right is still there, wonerdering if it may be a ball joint ?
just a quick update, it was the near side track rod end, fitted a new one and theres no knocking at all |
RRBlue Member Since: 24 Feb 2012 Location: Cambs Posts: 222 ![]() ![]() ![]() |
Monty1,
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8747 ![]() ![]() ![]() |
Excellent cheap fix.... There is nothing that can't be fixed with a hammer😜😜
I will check the track rod end when I do the service this week. |
I found my problem by moving the steering wheel quickly left and right whilst parked, it gave a clunking noise.
Is that the stabilizer link? |
That's them, cost 30 quid for both and half a hour to change |
