Home > Technical (L322) > How to open the 'clamshell' to replace worn compressor. |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3979 |
You have all the doors shut when trying the compressor? |
27th Mar 2013 6:35pm |
muffster Member Since: 03 Dec 2011 Location: Bradford Posts: 71 |
I hope so.
27th Mar 2013 8:41pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
No LED's means hard fault. Req a dealer, RAC, hawkeye, faultmate etc to reset. Once this is done you will be sorted for all heights. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
27th Mar 2013 8:49pm |
Well after all that it didn't work!
28th Mar 2013 9:38pm |
rgwatches Member Since: 19 Dec 2012 Location: United Kingdom Posts: 36 |
What did they try and clear it with and what was the exact fault? |
29th Mar 2013 12:41pm |
I use this and have never had a problem clearing faults, excellent for diagnostics to.
29th Mar 2013 12:43pm |
Iv'e no idea what they used when trying to clear the fault. They are a good outfit, it's Green Oval in Leeds. However i would have preferred it if they would have explained that i may risk having the suspension sagging down should the re-set fail.
29th Mar 2013 7:43pm |
Back to basics, have you checked the fuses and compressor relay?
29th Mar 2013 8:29pm |
Thanks for those diagrams.
30th Mar 2013 4:16pm |
Was the compressor working (albeit lazily) before you replaced the ring? |
30th Mar 2013 4:43pm |
It wasn't really working but it was held at the right height. Did jack it up at the front causing it to sag but it levelled itself out again after a few mins. Now it's completely knackerd, it appears I've made it worse by taking it to bits even though I replaced the piston ring and gave it all a good general clean up.
30th Mar 2013 5:05pm |
It's interesting you got the compressor to work for a few seconds after removing the relay. I assume this is the first time you have got the compressor to activate since you dismantled it
30th Mar 2013 5:19pm |
Yes mate that is an interesting point, though the garage did try another one . I guess they are bog standard relay, I might nick one from somewhere else just tho try it. |
30th Mar 2013 7:02pm |
It's a 50A relay, not sure there is another one on the car.
30th Mar 2013 7:32pm |
