Home > Maintenance & Mods (L322) > Wheel wobble at M/way speed with slight input to the wheel
Post #175441 2nd Mar 2013 7:44pm
T24RES
New lower arms are in. Will await the test drive.
Post #176246 6th Mar 2013 9:27pm
Did you read about adjusting the large rubber bush on the arm?? If you fully tighten it when the car is jacked up it causes stress on the rubber when it goes back to normal position. When you assemble, leave the bolt slackish, then when the car is at normal ride height fully tighten it up.
On a related note... I had a clicking noise when I was doing low speed manoeuvres. It was due to the bolt on the bush not being tight enough. The new bush was a fraction too small and the bolt had to be super tight to bend the bracket in to grip the sides of the metal tube through the rubber bush. Thumbs Up Previously..
Post #176258 6th Mar 2013 10:35pm
T24RES
I did thank-you. However getting a 3' torque wrench on the nut without it being on a ramp is not that easy.
I did buy a fork set and a 21mm spanner as i had neither in the box. She took some beating i can tell you.
Post #176268 6th Mar 2013 11:07pm
T24RES
Update following 800 mile trip North
Just returned from a w/end in Edinburgh. Lots of m'way miles and this appears to have cured my problem.
Thank-you Contraband Bow down
Post #178195 18th Mar 2013 1:20pm
Post #178196 18th Mar 2013 1:24pm
Sandyt
Good stuff replaced mine both sides the other month Thumbs Up Thumbs Up
Post #293168 15th Nov 2014 12:40pm
