Home > Maintenance & Mods (L322) > Engine Braking... |
shalz Member Since: 28 Jan 2013 Location: where FFRRs roam free...! Posts: 505 |
Hi,
7th Mar 2013 12:07am |
GreenBlood Member Since: 26 Feb 2013 Location: South West London, Surrey Posts: 84 |
I had a similar problem with mine and it was a seized rear brake caliper, eventually resulting in a warped brake disk. After driving feel for excessive heat in any of the wheels, it should be quite obvious if any are warmer than the others.
7th Mar 2013 5:11am |
Pfazz Member Since: 07 Apr 2012 Location: Stalybridge, Cheshire. Posts: 507 |
I have a 61 plate 4.4 and I don't experience any undue slowing of the car under deceleration or lag in acceleration in fact just the opposite under acceleration it it as smooth and lively as anything I have ever driven given the size of the beast, so I would let the dealer have a look if i were you. Agueroooooooooo. 93-20
7th Mar 2013 6:56am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35331 |
said police officer could have been T24RES [ian] from the forum..was he on a motorbike? ... - .- -. Y. O. L. O. . |
7th Mar 2013 8:18am |
Thanks I have a feeling you may be right - both front wheels give off a lot of heat compared to the back, although no burning smell. Both these wheels were replaced and aligned so maybe dealer it up. Will get it checked next week. Will it be ok to drive the odd short distance as I don't have another car to use?
7th Mar 2013 8:58am |
I can only speak from my experience. It seems my brake caliper was seized for a number of weeks and a few hundred miles before it became chronic and warped the disk. You will know when the disks are warped when you feel the judder at almost any speed especially after braking. The Land Rover Approved Warranty covered the seized caliper but not replacing the warped disks and pads. If you don't get stuck then you are not trying hard enough.
7th Mar 2013 9:21am |
Thanks. If it is the same issue, I'll try get it all replaced under the Warranty and if not, get the dealer who sold it to me 2 weeks ago to cover it as it isn't something I plan to, or should, take quietly.
7th Mar 2013 9:42am |
Fantastic! Would be great to hear the outcome. If you don't get stuck then you are not trying hard enough.
7th Mar 2013 1:50pm |
7th Mar 2013 3:33pm |
So just heard back from the dealer, apparently they can't hear any squealing noise when braking (and I must confess, the night before it was collected, it seemed to suddenly vanish!)
13th Mar 2013 10:11am |
Has the original symptom of the sensation of braking when just coasting whilst driving disappeared? If you don't get stuck then you are not trying hard enough.
13th Mar 2013 10:30am |
it was a little less on Sunday and on speaking to the service guy, he said they hadn't felt it at all. maybe this update/inspecting the brakes has cured it
13th Mar 2013 10:33am |
jim2RRs Member Since: 07 Feb 2012 Location: Genesee, Colorado Posts: 147 |
greasing the brake discs should elimate any occurance of resistance between the brake pads and the disc.
13th Mar 2013 10:16pm |
Thanks Jim, but will this not affect the performance of the brakes - you need the resistance?
13th Mar 2013 11:34pm |
