![]() | Home > General > Tow bar |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2051 ![]() ![]() |
Anyone know of any where to get 1 cheaper than stealers? Nigel
Jem0911 Member Since: 07 Jan 2010 Location: East Northants Posts: 357 ![]() ![]() ![]() |
There is a breaker in Beds who advertises them on Fleabay.
I had one made:
![]() Cost about �15 in material, I bought the square tube cut to length (but I made it a bit shorter) then the drop plate I bought from motofactors along with the pin that locks it into the car and the tow ball although you can buy them in Halfrauds or on eBay. Towed my 1750KG C'van 500 miles with no problem and I tow a small trailer 3 or 4 times a week with it at the moment ![]() |
I won't mention type approval if you don't |
That's the only reason why I didnt stick it on eBay for �75! |
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 ![]() ![]() |
I see you were thinking the same Thrasher.
Shaun the Sheep Member Since: 21 Mar 2010 Location: Bolton, Lancashire Posts: 48 ![]() ![]() ![]() |
So it's a towbar and not a plough then? |
GKP Member Since: 01 Aug 2009 Location: Hants Posts: 75 ![]() ![]() ![]() |
The Genuine Parts towbar for the two MYs differs just on where the rear silencer hangs. The mounting points between the two MYs is about two inches further back on the early cars and the exhaust rubbers bolt onto the towbar itself. No idea if the non-gen stuff requires this difference? Not sure you should be reading this bit. |
