Home > General > Tow bar
nbunney
Tow bar
Anyone know of any where to get 1 cheaper than stealers? Nigel
4.4 TDV8
North West Blood Bikes - Lancs and Lakes - Membership Secretary
NW 4x4 Response - responder
Post #17557 27th Apr 2010 11:31pm
delamo
England 2007 Range Rover Vogue SE TDV8 Tonga Green
Google Westfalia and search through the list of approved towbar suppliers.
They all appear to be matching each others prices - approx �350 for complete kit - 2 part detachable (same type that LandRover fit) - They reckon that you can fit yourself and can deliver within 24hrs.
Check that it is for 2007 spec L322 ( 2 different types for earlier/later L322's)
I have also been looking for a towbar - thinking I might be able to get one cheaper on eBay - but secondhand they are selling for same price as the suppliers are selling them new! Confused
Let me know if you find them selling for less elsewhere Thumbs Up
Post #17558 27th Apr 2010 11:56pm
Jem0911
United Kingdom 2015 Range Rover Vogue SE SDV8 Corris Grey
There is a breaker in Beds who advertises them on Fleabay.
I will look him up, I bought the Ball detach from them new �35 15MY SDV8 Vogue SE
Post #17560 28th Apr 2010 8:59am
dan_uk_1984
I had one made:
Cost about �15 in material, I bought the square tube cut to length (but I made it a bit shorter) then the drop plate I bought from motofactors along with the pin that locks it into the car and the tow ball although you can buy them in Halfrauds or on eBay.
Towed my 1750KG C'van 500 miles with no problem and I tow a small trailer 3 or 4 times a week with it at the moment
Post #17561 28th Apr 2010 9:11am
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
I won't mention type approval if you don't Whistle Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #17562 28th Apr 2010 9:14am
dan_uk_1984
That's the only reason why I didnt stick it on eBay for �75!
Post #17568 28th Apr 2010 10:26am
Fox
I see you were thinking the same Thrasher.
Although a tow bar like that may be fine, I'd be too scared to use it as the police inspection would not be very polite in the event of an accident...
I had an issue with a trailer two years ago. It flipped over onto it's side (with a Defender on it) and I was lucky to just end up with the back of my Defender lifted off the ground.
The police went through the car and trailer in minute detail.
Post #17569 28th Apr 2010 10:27am
Shaun the Sheep
England 2007 Range Rover Vogue TDV8 Stornoway Grey
So it's a towbar and not a plough then? Rolling with laughter Rolling with laughter
Post #17570 28th Apr 2010 10:27am
GKP
United Kingdom 2003 Range Rover Vogue 4.4 V8 Cairns Blue
The Genuine Parts towbar for the two MYs differs just on where the rear silencer hangs. The mounting points between the two MYs is about two inches further back on the early cars and the exhaust rubbers bolt onto the towbar itself.
No idea if the non-gen stuff requires this difference? Not sure you should be reading this bit.
Post #17678 29th Apr 2010 7:26pm
