Home > Maintenance & Mods (L322) > Wiring up side lights as DRL on an 05-09 model |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
Am I missing something here? Why not just leave your sidelights on all the time with nice bright LED bulbs in?? Previously..
24th Feb 2013 4:32pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6405 |
IIDTool setting change on the LCM ?
24th Feb 2013 5:07pm |
Stryke Member Since: 16 Nov 2010 Location: UK Posts: 262 |
Just converted the front end to a 2010-12 front end and would like the Leds on the front to come on full time. |
24th Feb 2013 7:15pm |
Tried the IIDTool, only allows dipped or main beam. As it's a 2010-12 front end would be nice if the side light leds could be drls. |
24th Feb 2013 7:16pm |
spanner Member Since: 05 Jun 2011 Location: uk Posts: 134 |
you could wire in a relay that is powered from ignition and feed just front side lights splicing the wiring coming from ecu |
24th Feb 2013 7:35pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35110 |
buy a drl switch of ebay (about £ and wire it to your sidelights.. ... - .- -.
24th Feb 2013 7:42pm |
You got a link? |
24th Feb 2013 7:51pm |
nope, search 'drl switch'.... ... - .- -.
24th Feb 2013 7:59pm |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 |
i have just checked my faultmate system and the only things you can enable on the LCM for DTR lights on is dip or main beam, hope this helps.
24th Feb 2013 8:32pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3964 |
A drl relay won't do what you require.
24th Feb 2013 8:35pm |
"nicedayforit" thanks for that, will get my auto-electrician over next week and ask him to carry out this modification.
25th Feb 2013 12:51am |
