![]() | Home > Maintenance & Mods (L322) > Wiring up side lights as DRL on an 05-09 model |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
Am I missing something here? Why not just leave your sidelights on all the time with nice bright LED bulbs in?? Previously..
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
IIDTool setting change on the LCM ?
Stryke Member Since: 16 Nov 2010 Location: UK Posts: 262 ![]() ![]() ![]() |
Just converted the front end to a 2010-12 front end and would like the Leds on the front to come on full time. |
Tried the IIDTool, only allows dipped or main beam. As it's a 2010-12 front end would be nice if the side light leds could be drls. |
spanner Member Since: 05 Jun 2011 Location: uk Posts: 134 ![]() |
you could wire in a relay that is powered from ignition and feed just front side lights splicing the wiring coming from ecu |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35643 ![]() ![]() |
buy a drl switch of ebay (about £ |
You got a link? |
nope, search 'drl switch'.... ... - .- -.
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 ![]() ![]() ![]() |
i have just checked my faultmate system and the only things you can enable on the LCM for DTR lights on is dip or main beam, hope this helps.
A drl relay won't do what you require.
"nicedayforit" thanks for that, will get my auto-electrician over next week and ask him to carry out this modification.
