Home > Maintenance & Mods (L322) > Wiring up side lights as DRL on an 05-09 model
Stryke
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Hi guys,
Any one know what is required to have the side lights as daytime running lights?
Thanks.
Post #174241 24th Feb 2013 3:07pm
Am I missing something here? Why not just leave your sidelights on all the time with nice bright LED bulbs in?? Previously..
Post #174244 24th Feb 2013 3:32pm
IIDTool setting change on the LCM ?
[EDIT] only for dipped or main beam.
IMO the best solution is the fog light one Wink .
Post #174258 24th Feb 2013 4:07pm
Stryke
Just converted the front end to a 2010-12 front end and would like the Leds on the front to come on full time.
Post #174290 24th Feb 2013 6:15pm
Stryke
Tried the IIDTool, only allows dipped or main beam.
As it's a 2010-12 front end would be nice if the side light leds could be drls.
Post #174291 24th Feb 2013 6:16pm
spanner
you could wire in a relay that is powered from ignition and feed just front side lights splicing the wiring coming from ecu
Post #174297 24th Feb 2013 6:35pm
buy a drl switch of ebay (about £Cool and wire it to your sidelights.. ... - .- -.
Post #174299 24th Feb 2013 6:42pm
Stryke
You got a link?
Post #174304 24th Feb 2013 6:51pm
nope, search 'drl switch'.... ... - .- -.
Post #174306 24th Feb 2013 6:59pm
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
i have just checked my faultmate system and the only things you can enable on the LCM for DTR lights on is dip or main beam, hope this helps.
Matt
Post #174326 24th Feb 2013 7:32pm
A drl relay won't do what you require.
You need a simple 3 or 5 pin changeover relay and wire as below.
I don't think the additional small current to operate the relay coil should affect the LCM.
Post #174327 24th Feb 2013 7:35pm
Stryke
"nicedayforit" thanks for that, will get my auto-electrician over next week and ask him to carry out this modification.
Thanks for the diagram.
Post #174389 24th Feb 2013 11:51pm
