Home > Technical (L322) > ignition lock slow
RichTDV8
United Kingdom 2015 Range Rover Vogue SE TDV6 Corris Grey
ignition lock slow
hi all
have a problem with my ignition lock. if the car is left for a few days the ignition lock barely comes to life and is very slow but is fine after the cars been running. Battery is fine less than 12 months old.
could I need a new barrel for the ignition??
thanks 3.0 VSE - 2015MY
Corris with Black, RSE, 22 turbines, privacy, deployables
Post #174055 23rd Feb 2013 12:59pm
SoggyBottoms
United Kingdom 2007 Range Rover Vogue Supercharged Zambezi Silver
I found mine was slow when the battery hadn't been charged / topped up for a while
I put mine on a C Tek every month and replaced battery for 110
Post #174073 23rd Feb 2013 4:36pm
RichTDV8
thanks SB it definitely only happens when left for a few days 3.0 VSE - 2015MY
Post #174128 23rd Feb 2013 9:55pm
my battery started feeling low on power only after about 10 months, mainly cos i didnt use it very much, as said above charge it up or get a replacement. ... - .- -.
Post #174158 24th Feb 2013 9:14am
Mine did the same, and now it doesn't work at all! TBH I don't care, as I know if I investigate it the dealers will tell me it's a new steering motor or something that will cost me a fortune. Discovery 4 HSE
Post #174165 24th Feb 2013 9:34am
Get the automatic in/out with ignition cycle turned off via diagnostics... Will also save the life of the motors too Thumbs Up
Post #174179 24th Feb 2013 11:07am
Robgosty
Know this is an old thread but I have same problem with ignition lock slow to respond when key inserted, this was after a hard battery reset, I am aware steering column movement can be removed but post from Craig seems to suggest ignition lock can be coded out, if so can it be done with IID tool ?
Post #347502 13th Sep 2015 9:17am
