![]() | Home > Technical (L322) > Coolant Loss; Where to Look? |
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 ![]() ![]() |
Got back from a trip to Belfast last night and then had to go to work this morning.
Deasy Member Since: 26 Oct 2011 Location: Warwickshire Posts: 210 ![]() ![]() ![]() |
Errrrrrrrrmmmm 42??
Ya, it's hard to see much in the dark with a torch and I'm working 12 hours shifts for the next few days so it'll be Thursday before I can have a good look in daylight.
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 474 ![]() ![]() ![]() |
I recently had to replace my expansion tank - hairline fracture which wasn't obvious at first. It's worth checking just to eliminate it from the list of possibles. |
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4995 ![]() ![]() ![]() |
i recently replaced the radiator ... |
Jr-auto-electrics Member Since: 15 Jan 2012 Location: West Midlands Posts: 189 ![]() ![]() ![]() |
I'd say rad as first point of call
It's a strange one this.
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 ![]() ![]() |
How long ago did you last check the coolant level before the recent warning ? |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
If you have taken the cap off you will have released all the pressure from the system that would have been forcing the coolant out. If its not leaking without being under pressure the leak I would guess it isn't the biggest of leaks. My money is on the rad if its never been changed. Get the fan off and remove the fan cowel and get a good look at it. New rads about �160 and easy to fit once you have the fan off.
Before we left Belfast for the return journey on Thursday night. We drove into Belfast to catch the ferry to Cairnryan on Friday morning and then drove to Fort William, overnight there and then drove through Skye to catch the ferry to Harris and it's about an hour from Tarbert to home. ![]() |
I didn't have any choice when I filled it at work but I'm going to get some antifreeze in there today. The low coolant alarm hasn't returned yet though. ![]() |
It's the water pump. |
Geo2toy Member Since: 04 Nov 2012 Location: Wiltshire Posts: 76 ![]() ![]() ![]() |
Sometimes the small coolant pipe behind the waterpump leaks. |
