Home > Technical (L322) > Coolant Loss; Where to Look?
Budgie
Got back from a trip to Belfast last night and then had to go to work this morning.
Started the FF and got the "Check Coolant Level" warning on the dash, I was running late so thought it would be OK and I'll check it before heading home tonight.
I opened the header tank this evening and the thing was near empty so I topped it up with water and headed off to home. Got the same message on the way home so let it cool down a bit and had a look (in the dark) to see some brown coolant laying on the plastic under-tray on the drivers side.
I can't tell whether it's from the water pump, trans cooler, radiator or a split pipe somewhere. So I'm looking for pointers of where to start checking without having to remove too much stuff. Thumbs Up
See, give her an gearbox oil & filter change, as spray with oil underneath and good long, and this is the thanks you get!! Laughing
Cheers for any advice.
Martin.
Post #172934 17th Feb 2013 10:17pm
Deasy
Errrrrrrrrmmmm 42??
It really could be anywhere, you need to get under it and find out
I have had a few coolant loss issues with mine, biggest being water ump failure, and simplest being jubilee clip that needed nipping up....
Post #172936 17th Feb 2013 10:26pm
Budgie
Ya, it's hard to see much in the dark with a torch and I'm working 12 hours shifts for the next few days so it'll be Thursday before I can have a good look in daylight.
I'll just keep a water bottle in the car until then. Wink
Post #172938 17th Feb 2013 10:40pm
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
I recently had to replace my expansion tank - hairline fracture which wasn't obvious at first. It's worth checking just to eliminate it from the list of possibles.
Post #172968 18th Feb 2013 8:24am
i recently replaced the radiator ... Sad All my spelling errorz are belong to me!
2023 FFRR L460
2021 AM new Vantage
Post #172978 18th Feb 2013 9:29am
Jr-auto-electrics
England 2004 Range Rover Vogue Td6 Java Black
I'd say rad as first point of call
Remove two plastic pins on top rad shroud and look down the side of the rad
Any red residue is signs of slow leak very very common on the l322
Not sure if just the diesel or petrol as well RANGE ROVER 04 TD6
RANGE ROVER ULTIMATE EDITION 2012
UPGRADE.
MK 4 SATNAV
http://www.flickr.com/photos/jrautoelectrics/
Post #173188 18th Feb 2013 7:08pm
Budgie
It's a strange one this.
After the initial refill there's been no more coolant loss as all. I checked it this morning before going to work and it was fine. Checked it again at work and still no signs of any more loss, the header tank is still full, so I've no idea why it through out the coolant after the long run and then nothing. Rolling Eyes
I'm still going to take a closer look as I need to find out where it came from in the first place.
Thanks for the pointers. Thumbs Up
Post #173260 18th Feb 2013 10:51pm
steptoe
How long ago did you last check the coolant level before the recent warning ?
Post #173285 19th Feb 2013 9:38am
If you have taken the cap off you will have released all the pressure from the system that would have been forcing the coolant out. If its not leaking without being under pressure the leak I would guess it isn't the biggest of leaks. My money is on the rad if its never been changed. Get the fan off and remove the fan cowel and get a good look at it. New rads about £160 and easy to fit once you have the fan off.
I got quoted £500ish for a custom ali rad. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #173289 19th Feb 2013 9:53am
Don't use plain water to top it up or the dash light will tell you that the coolant is low
Post #173294 19th Feb 2013 9:58am
Budgie
Before we left Belfast for the return journey on Thursday night.
We drove into Belfast to catch the ferry to Cairnryan on Friday morning and then drove to Fort William, overnight there and then drove through Skye to catch the ferry to Harris and it's about an hour from Tarbert to home.
Post #173300 19th Feb 2013 11:34am
Budgie
I didn't have any choice when I filled it at work but I'm going to get some antifreeze in there today.
The low coolant alarm hasn't returned yet though.
Post #173302 19th Feb 2013 11:37am
Budgie
It's the water pump. Rolling Eyes
I had chance to have a look in daylight and the main shaft and left hand side of the pump body (looking from the radiator) is damp and reddish in colour from the coolant. So new pump, gasket, o-ring and drive belts (thought I may as well change them while it's all in bits Very Happy ) on order from Island 4x4 in Kent.
Thanks to Saint.V8 for the water pump tutorial in the Wiki section, that'll come in handy!! Thumbs Up
I'll let you all know how it goes but it could be a week or so before I get round to it. Wink
Post #173315 19th Feb 2013 1:13pm
Thumbs Up All my spelling errorz are belong to me!
2023 FFRR L460
2021 AM new Vantage
Post #173524 20th Feb 2013 8:00am
Geo2toy
United Kingdom 2011 Range Rover Vogue SE TDV8 Java Black
Sometimes the small coolant pipe behind the waterpump leaks.
Post #179136 22nd Mar 2013 5:33pm
