Home > Technical (L322) > Ignition fault |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35272 |
sounds like a plan Nick..a bit like the bmw start buttons i suppose...
18th Feb 2013 2:17pm |
Nicka2311 Member Since: 29 Dec 2012 Location: Scotland Posts: 51 |
Cheers Stan, hopefully it's a straight shot once I take that out, I currently have barely any dash as it is, all that's left is top panel, facias and glove box '55 Java Black Vogue |
18th Feb 2013 2:24pm |
if your dash is in that state then it would be interesting if you can find another route through the bulkhead, this will help other members who want to run a cable through.. ... - .- -.
18th Feb 2013 2:31pm |
I'll put some pics up of the route I find for the cable and if it's something people are interested in, maybe a how to guide. '55 Java Black Vogue |
18th Feb 2013 2:35pm |
nice one ... - .- -.
18th Feb 2013 2:36pm |
Right, button is wired in, took a feed from battery to switch and then onto starter trigger. The switch will turn the starter but it sounds as if the solenoid hasn't pushed it out to engage the flywheel, is there a seperate trigger for this as I shoved a screwdriver down to the trigger and bridged it onto the live feed to starter and we had lift off. (without using the button)
21st Feb 2013 2:51pm |
pretty sure you're the first to do this so bear with us, someone might know.. ... - .- -.
23rd Feb 2013 12:36pm |
It looks like the starter isn't receiving the full 12v supply needed so I'm going to install a relay switch further down the cable.
23rd Feb 2013 6:49pm |
wats39 Member Since: 08 Jul 2012 Location: fife Posts: 77 |
You ain't trying to power the starter motor, ie the big battery cables, with the push button switch by any chance are you? that would maybe explain why the starter is not engaging. either that, your battery might be going flat. the starter will have a solenoid built in that has a small wire to switch it. thats what you want to connect your push button switch to. remember to take the power for your push button switch from the ignition though. if you take it from the battery then the engine will be able to turn over without the ignition switched on. '04 td6 se
23rd Feb 2013 8:24pm |
Im running my signal (power) cable from the battery through the push button start onto the solenoid for the starter motors actuator not the battefy power cable. when Im turning the starter its only showing 8 volts. Yhis is why I then took a wire from the battery cable on the starter into a relay, the relay then runs onto the trigger switch for the starter and the push button now triggers the relay.
24th Feb 2013 9:41pm |
Never mind, cracked it and Im loving the push to start '55 Java Black Vogue |
25th Feb 2013 4:47pm |
What was the problem with it Nicka? '04 td6 se
25th Feb 2013 10:17pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
Any pictures / howto of the modification, sounds great ? .
26th Feb 2013 12:26pm |
Wire gauge was syphoning off some voltage and not getting 12v to starter.
27th Feb 2013 12:32pm |
