Home > Technical (L322) > Ignition fault |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35264 |
so you just insert the key [without turning it ?] and then press the red button ...
1st Mar 2013 11:55am |
Nicka2311 Member Since: 29 Dec 2012 Location: Scotland Posts: 51 |
Start procedure is as normal, turn key to position 2 and press the button, rather than turning to position 3, which is now not needed, so it is the same number of steps and engine off is simply key off. I could bypass the whole ignition system and replace the barrel with the button start, but it would make it considerably easier to steal.
1st Mar 2013 12:06pm |
its very similar to the bmw start button jobby except for the extra key turn.....nice job btw. ... - .- -.
1st Mar 2013 12:12pm |
I'm missing the extra key turn you mention.
1st Mar 2013 12:17pm |
the bmw system is , put key fob in and fully press the start button ,with your foot on the brake for autos...
1st Mar 2013 12:40pm |
Ah ok, I know the mode your talking about, there is a 3 step way to work them as we use it to plug in an OBDII reader when reading fault codes.
1st Mar 2013 12:47pm |
