Home > Technical (L322) > Trans Failsafe Prog - Another one!! |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 |
The FF has been sat on the drive, unmoved for the past 3 1/2 weeks - most of that has been under a foot of snow.
3rd Feb 2013 12:07pm |
It was all going so well.............* BONG * TRANS FAILSAFE PROG
11th Feb 2013 6:57pm |
Hi All,
13th Feb 2013 6:01pm |
I had the TFSP Bong today after simply turning the ignition on. I hadn't even started the FF, let alone driven anywhere.
14th Feb 2013 7:36pm |
All,
13th Mar 2013 9:31am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35433 |
here's Phils profile page, you can pm or email him..
13th Mar 2013 9:48am |
Hi Stan,
13th Mar 2013 9:59am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6410 |
I have the same problem SKOT, if I put in Low Range it stays there, although the shift motor seems to be fine ( I even bought a new one to prove that point! ) Not been able to diagnose the cause as with an old motor I have been able to manually wind the transfer unit back up to High Range. Done transfer box oil change and gearbox oil change too. Hopefully yours is just a knackered shift motor .
13th Mar 2013 3:08pm |
someone has done a really good 'how to' re shift motors on the wiki.... ... - .- -.
13th Mar 2013 3:31pm |
.........And a very good write up it is too!
13th Mar 2013 4:30pm |
@ stan.
13th Mar 2013 10:15pm |
Question - If I can get the L322 into high range, and I remove the transfer box motor, part IGH500010 (will it still start and drive OK? I'm guessing there will be dash errors galore but will it still physically operate?
14th Mar 2013 2:32pm |
Hi All,
16th Mar 2013 12:10pm |
There is also the reset procedure. (which is what you are "supposed" to do if you change the TSM) Removing fuse 37 might help here ?
16th Mar 2013 12:22pm |
Hi Joe,
16th Mar 2013 12:28pm |
