Home > Technical (L322) > Transfer box motor?
Page 2 of 7 <1234567>
RRPhil
Glideman wrote:
....I stripped the motor down and the problem seems to be the bushes on the motor. They are all broken & worn....
Hi Glideman, yes - I've seen the crumbling brush problem before :
http://www.rangerovers.net/forum/6-range-r...post344401
I�ll probably have a (used) armature & brush set lying around somewhere so give me a shout if you get stuck.
Phil
Post #156346 9th Dec 2012 8:10pm
Glideman
Location: Stood next to a broken down Range Rover in Darwen
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Ok Phil, that's a very kind offer. I'll pay you for it of course. See how Ellisons do, they may be able to repair it. Range Rover 4.4 V8 Vogue
Post #156367 9th Dec 2012 9:38pm
SATVC
United Kingdom 2004 Range Rover Vogue Td6 Java Black
So I bought a new transfer motor!
My mech fitted it yesterday and said its now in trans fail safe and now is in limp mode? He said he can't access the ecu or auto box via his diagnostics ? He's saying that it'll have to go to a land rover dealer to have the codes cleared?
Unfortunatly no dealer local can do anything till the end of january??
This sounds expensive and long winded? Is there any manual way to clear these?
Prob is its stuck in limp mode and I can't really drive it? I keep thinking I've bought the wrong car???
Post #157468 14th Dec 2012 6:33pm
wouldnt a IIDTool clear these errors.. ... - .- -.
Post #157469 14th Dec 2012 6:39pm
RRPhil
You shouldn�t need to reset a TRANS FAILSAFE PROG error as it should reset itself each time the ignition is switched off & on. Your issue must be always there. How does the transfer box shift motor react to the manual calibration procedure?
Phil
Post #157479 14th Dec 2012 6:55pm
SATVC
Cured!!
Thanks guys!
After trying the calibration, with no joy we found fuse 52? (ecu power?) Had blown, after replacing the fuse and deleting codes then doing the calibration again all works perfect!
Amazing what a bit of luck, knowledge and good eyesight can do. my love for my full fat has returned!
Thanks for your help
Post #157494 14th Dec 2012 7:56pm
Fame
Portugal 2002 Range Rover Vogue Td6 Java Black
My transfer box started to make crunching sound and now and then, remained in high or low with the yellow mountain symbol flashing on dash.Cured flashing by turning on and off ignition. Went to my Indie, who removed the motor " cleaned all movable parts and lightly lubed all. Replaced and now working well again.( cost was 60 Euro) Told to USE
MORE OFTEN , 3-4 times a week, so as Kurt posted, I try to it daily up any slopes I encounter.Don'tw if permanent fix or not - time will tell Range Rover Vogue TD6 2002
Defender TD5 90Hard Top 2001
Range Rover Classic TDi 1994
Mercedes Benz 1959 220S Sedan
Post #157548 14th Dec 2012 11:04pm
Good news for both of you Thumbs Up
If only my problem was as easy Confused .
Post #157552 14th Dec 2012 11:13pm
Dolphinboy
Just wanted to say
RRPhil ....... You are a god!!
Bow down Bow down Bow down Bow down Bow down Bow down Bow down Bow down Bow down Bow down
Post #157558 14th Dec 2012 11:31pm
Glideman
I've sorted mine to after taking the motor to a local starter & alternator repairer. The brushes has shattered in the drive motor. They replaced the bushes for �30. I did strip the gears down, it was built without any lube and gave it a light grease re-fitted it and it worked first time.
I'd also like to thank Phil for his kind support and help with this problem Thumbs Up Range Rover 4.4 V8 Vogue
Post #157772 16th Dec 2012 12:57pm
Glideman
Just a quick update on this problem. It's now playing up again & the gearbox has gone into fail-safe mode. I'm trying to find a good second hand motor if anyone has one lying around? As RRPhil said it must be the electronics that's at fault & not the motor. The car is off the road again, the fifth time in the last 12 months Big Cry Range Rover 4.4 V8 Vogue
Post #168924 30th Jan 2013 9:44pm
If its the electronics, why do you need another TB motor? .
Post #168990 30th Jan 2013 10:58pm
Glideman
It's the potentiometer Range Rover 4.4 V8 Vogue
Post #168992 30th Jan 2013 11:03pm
JohnnyDangerous
England 2002 Range Rover Vogue 4.4 V8 Java Black
I found several on ebay for �3-350 when I was looking last week, ended up getting one for �70 worked just fine, my guys at work reckon the potentiometer can be sourced or remade, I must try and find out. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #168996 30th Jan 2013 11:08pm
Glideman
A re-manufactured one sounds good Thumbs Up Range Rover 4.4 V8 Vogue
Post #168997 30th Jan 2013 11:10pm
