![]() | Home > Technical (L322) > Transfer box motor? |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 982 ![]() ![]() |
Hi Glideman, yes - I've seen the crumbling brush problem before : http://www.rangerovers.net/forum/6-range-r...post344401 I’ll probably have a (used) armature & brush set lying around somewhere so give me a shout if you get stuck. Phil |
SATVC Member Since: 25 Nov 2012 Location: Surrey Posts: 172 ![]() ![]() ![]() |
So I bought a new transfer motor!
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35499 ![]() ![]() |
wouldnt a IIDTool clear these errors.. ... - .- -.
You shouldn’t need to reset a TRANS FAILSAFE PROG error as it should reset itself each time the ignition is switched off & on. Your issue must be always there. How does the transfer box shift motor react to the manual calibration procedure?
Cured!!
Fame Member Since: 01 Dec 2012 Location: Oliveira do Hospital Posts: 42 ![]() ![]() ![]() |
My transfer box started to make crunching sound and now and then, remained in high or low with the yellow mountain symbol flashing on dash.Cured flashing by turning on and off ignition. Went to my Indie, who removed the motor " cleaned all movable parts and lightly lubed all. Replaced and now working well again.( cost was 60 Euro) Told to USE
Good news for both of you |
Just wanted to say
Glideman Member Since: 11 Sep 2011 Location: Stood next to a broken down Range Rover in Darwen Posts: 112 ![]() ![]() ![]() |
I've sorted mine to after taking the motor to a local starter & alternator repairer. The brushes has shattered in the drive motor. They replaced the bushes for £30. I did strip the gears down, it was built without any lube and gave it a light grease re-fitted it and it worked first time.
Just a quick update on this problem. It's now playing up again & the gearbox has gone into fail-safe mode. I'm trying to find a good second hand motor if anyone has one lying around? As RRPhil said it must be the electronics that's at fault & not the motor. The car is off the road again, the fifth time in the last 12 months |
If its the electronics, why do you need another TB motor? .
It's the potentiometer Range Rover 4.4 V8 Vogue |
JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833 ![]() ![]() ![]() |
I found several on ebay for £3-350 when I was looking last week, ended up getting one for £70 worked just fine, my guys at work reckon the potentiometer can be sourced or remade, I must try and find out. One day your life will flash before your eyes......................................make sure yours is worth watching!
A re-manufactured one sounds good |
