![]() | Home > Technical (L322) > Transfer box motor? |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 806 ![]() ![]() ![]() |
Just been reading this with interest, good info to remember. Just a thought, has anyone had experience of a product called Superslide, its a graphite based lube used by Piano techs. I recall reading it being used to repair pots on vintage radios. It is painted on and dries, the more coats the less resistance,...
ndg Member Since: 25 Mar 2016 Location: Warwickshire Posts: 94 ![]() ![]() ![]() |
Thanks for the info on this issue. I pulled the potentiometer out yesterday, split it and tweaked the pins/re-melted the soldered joints and rejoined the two halves. High low now working perfectly.
Jimmy C Member Since: 05 Feb 2015 Location: midlands Posts: 115 ![]() ![]() ![]() |
Dont fancy doing another do you? |
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 ![]() ![]() ![]() |
I'd be happy to. Frankly it's pretty simple once you get your head round it! |
Likewise,
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
Same here for the Frenchies in need. |
I'll take you up on that offer, im near Leicester so not to far away, will be 2/3 weeks though as im on holiday after today ![]() |
Drop me a message when you've back and I'm sure we can sort something out |
This is another product I think would make a good repair, its used amongst other things to paint cavities in electric guitars to stop Hum. Its black carbon based. http://www.ebay.com.au/itm/Electric-Wire-D...Sw8-tWW-vO 2007 TDV8 VSE
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Got to ask, as LR are no help... is this not the same thing?
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1000 ![]() ![]() |
Certainly looks similar, but the NV225 shift motor potentiometer has a hexagonal recess on its underside to locate and align it
This vidio shows the guts of the GM motor and Potentiometer swap. I wonder if the innards of the potentiometer could be swapped from the GM to RR one?
I'm wondering if it wont just fit.. it has the notch, but not the hex bit... but the hex bit looks to be raised so maybe the GM one will just fit |
