Home > Technical (L322) > Bluetooth always on? |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3763 |
I have a problem with my battery going flat from time to time - regularly in fact. One thing I have noticed which may or may not be relevant is that if I take a call on my mobile in the house the BT in the car takes over, which means its on even though the car is locked up and "asleep". My previous cars have not done this - so my question is simple is this normal behaviour or should I be taking a closer look.
25th Jan 2013 7:26pm |
Switch your bluetooth off on your phone either that or park your car at the end of the street you must be quite near the car when you take a call ====================================
25th Jan 2013 7:35pm |
It's the downside of not having a country estate, if there were no glass I could touch my car though the window from where I'm sitting Geoff |
25th Jan 2013 7:41pm |
BUT is the car still looking for a BT connection all the time Geoff |
25th Jan 2013 7:42pm |
My guess is when you are phoning the car might still be picking up the signal and booting up if it is not properly going to sleep …
25th Jan 2013 7:56pm |
simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650 |
Hi Geoff
25th Jan 2013 8:06pm |
dave699 Member Since: 03 Apr 2012 Location: Redcar Posts: 457 |
If I get a call immediately after getting out of the car and prior to the car 'going to sleep', it automatically transfers to car.
25th Jan 2013 8:13pm |
I'll just pull the BT module and see if it makes any difference or can I switch it off? Micks right I need someone who knows stuff to advise Geoff |
25th Jan 2013 8:14pm |
wiggs Member Since: 29 May 2010 Location: Manchester Posts: 182 |
If some thing is stopping your car going to sleep the Bluetooth will always be on .
25th Jan 2013 8:24pm |
That's what I call good service Geoff |
25th Jan 2013 9:00pm |
My newer module stopped almost as soon as the key was removed from the lock. My older upgraded one seems to take a few minutes for the car to go to sleep to fully close down but on an iPhone you can change tte audio source once you answer the phone FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
25th Jan 2013 9:25pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16263 |
Sorry to interupt your thread but did you get my PM about DVD Changers Adrian? |
26th Jan 2013 2:10am |
I did thanks
26th Jan 2013 7:32am |
