Home > Technical (L322) > Steering Vibration |
wats39 Member Since: 08 Jul 2012 Location: fife Posts: 77 |
Might be worth checking the mounting faces where the wheel and hub bolt together to make sure they are clean. this would cause the steering wheel to shake. '04 td6 se
24th Jan 2013 8:36pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3137 |
could be a binding brake caliper. had this on mine last week - vibration through the steering wheel at 50-60 mph. Took wheel off, checked brake was free, now vibration gone, all good! |
24th Jan 2013 10:19pm |
spanner Member Since: 05 Jun 2011 Location: uk Posts: 134 |
Thats interesting when you say binding what exactly was causing the bind |
25th Jan 2013 7:01am |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2643 |
Binding usually caused by a perished rubber seal on the caliper piston, had this ages ago. After a run , touch the wheel, if its hot, caliper sticking on, mine used to get so hot the pads would be smoking like a bstard. |
25th Jan 2013 7:36am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35276 |
if it drove ok before the work was done then the problem is related to the work carried out, take it back and complain.. ... - .- -.
25th Jan 2013 8:20am |
I did Stan I got under the car with my mechanic we went through everything but could not find a thing however the brake calipers had to come off and it sounds plausible that this is the issue |
25th Jan 2013 8:40am |
seems to point to the callipers..let us know the out come Spanner.. ... - .- -.
25th Jan 2013 8:43am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Ring your mechanic and ask if he has an infrared thermometer... Then arange a time you can "GENTLY" drive the car to him and he can zap both wheels and compare the temps...
25th Jan 2013 8:50am |
