Home > Technical (L322) > Door frozen open... |
Had it on my old Peugeot and was a nightmare. Never resolved it. Try to spray WD 40 on the lock mechanism that you see when the door is open. If that doesn't help get the door card of and spray it onto the mechanism. MY 2010 5.0 SC Galway green and sand interior!!
17th Jan 2013 1:09am |
Norway Member Since: 09 Dec 2012 Location: Høvik Posts: 123 |
Hi, i have this When its under 15 minus. I direct the heater at the door and after about 5 mins it looks. I tried some lock oil with positive result, but I guess this really has to do with a worn lock. Does your door sometimes not open on the first attempt. Mine opens only half way, when is that cold. I have not bothered doing anything to solv it.
17th Jan 2013 1:48am |
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 |
Had this myself yesterday morning (-11.5 at 0350 hrs) whilst driving to work. What I had to do was hold the door shut and press the central locking button (this kept them shut enough to stop them opening) and turned the interior light off ! After 40 miles with the heater on I could then stop and shut them properly ! Not ideal but it worked |
17th Jan 2013 4:19am |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 |
I had exactly the opposite problem yesterday. My door opened fine on the driveway. Closed fine, too.
17th Jan 2013 7:53am |
ollielloyd Member Since: 09 Oct 2012 Location: United Kingdom Posts: 120 |
Had it past couple of days. All I do is fill kettle with warm water from tap and then pour on door/handle. By time I come back with second kettle of water it's closing. |
17th Jan 2013 8:38am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35114 |
its happened to me as well, the door lock mechanism freezes and stops the latch from engaging...
17th Jan 2013 9:45am |
NKSC Member Since: 09 Nov 2011 Location: Lincs Posts: 156 |
I had this problem on mine last winter, and as Stan says the door card need to come off and the mechanism needs greasing to stop it freezing.
17th Jan 2013 10:11am |
Looking in the Wiki at the rear door card removal video by Powerfull, is taking the front door card off the same procedure or are there any other little tricks to be aware of? Si. <This is my name.
17th Jan 2013 10:15am |
There is a front door card removal video on the Powerful website. |
17th Jan 2013 10:31am |
17th Jan 2013 10:33am |
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 738 |
Think I'll leave the door card alone - and try the locking button method |
17th Jan 2013 10:48am |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2934 |
You'd think being a supposed "go anywhere" all weather vehicle, this wouldn't happen! Mine does the same thing |
20th Jan 2013 6:09pm |
Well it is british. -03V td6
20th Jan 2013 8:17pm |
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 |
Tell me about it!
21st Jan 2013 8:38am |
