Home > General > Injector overhaul... in he goes. |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 |
Well, I have the RR back, the Injectors were removed and sent away for full overhaul and new nozzles. I have 77,000 miles so hopefully it will be good for another 77000 miles now.
14th Apr 2010 4:01pm |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 780 |
Do you by any chance have a code for the injectors? Are they all identical? Thank you! |
18th May 2010 6:19am |
No, I had the existing injectors removed and rebuilt with new washers and new nozzles. I know replacement injectors would need to be programmed to tell them which eu settings to run at. Sorry I don't have a part number. How is the turbo doing? |
18th May 2010 6:57am |
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 |
Out of interest, what did it cost in the end to get them all done? |
18th May 2010 7:21am |
Repairing looks like a great idea as RAVE says that: “If one or more injectors are replaced, the
18th May 2010 7:30am |
All done inc VAT £1038 local non franchised repair centre specialist in Landrovers. Keep in mind I only had five done. In the end it was around £130 plus vat each injector as I had new nozzles to, belt and braces.
18th May 2010 6:53pm |
