![]() | Home > Maintenance & Mods (L322) > HOWTO: Change Thermostat on '02 TD6 FFRR |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Another lost weekend, another photo tutorial |
Nice work Joe, I'll give you a shout when mine needs changed |
Damn, needle dropping to left on downhill runs again |
No, have been watching it, and with warmer temperatures of late it has been less of a problem. With the cold snap coming I guess I will see more of the same. Never goes over 12 o'clock, so I don't think it is the thermostat, or if it is stuck open ther rest of the cooling system is doing its job by working as it should.
DavidP Member Since: 20 Oct 2010 Location: BN Posts: 425 ![]() ![]() ![]() |
Thanks, it's a strange one. My FBH is working, it does take a little longer to heat up. The fluctuation seems to be getting more frequent and was only when travelling down hill. That being said i did a short drive last night, needle to normal, left the car running [whlst checking the horses] came out to find the needle at 1/4 position - it then took 10km to come back up. This morning -4 a little longer to heat up but steady at the mid-point for the rest of the journey...... |
Agreed my journey to work today in 0 degrees, warmed up to 12 o'clock as normal by @ 10 miles of A road, steady on the motorway, then dropped on a long downhill run on the motorway, then in traffic for 20 minutes stayed at @ 10 o'clock. Damned efficient engine this TD6 ....... .
I will be having it looked at in the near future - if any discoveries are made i will let you know......Thanks |
Had plenty of heat in the cabin though, no problems there.... .
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
Worth checking the other thermostat above the EGR cooler on the front of the engine. |
??????? ![]() Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35633 ![]() ![]() |
...next to the falange... ... - .- -.
I'm not joking, have a look above the EGR cooler, you'll find one there, about �30 if I remember rightly.
@Joe - also had cabin heat.
666tur Member Since: 15 Feb 2013 Location: Nottingham Posts: 108 ![]() ![]() ![]() |
My car suffered from very similar symptoms to the OP, highlighted over the recent cold spell, struggling to get beyond the quarter level on the gauge . Using the hidden menu the car was struggling to achieve 80c (via hidden menu) despite been driven for an hour. On very cold days it was struggling to heat the cabin! I referred the issue to the servicing dealer but their vague comments and could be this or that left me with no confidence.
