![]() | Home > Maintenance & Mods (L322) > HOWTO: Change Thermostat on '02 TD6 FFRR |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35611 ![]() ![]() |
hidden menu's = wiki.. ... - .- -.
Got a new rad, thermal valve and coolant tank going in at the end of the month, so will see if this sorts things out! |
666tur Member Since: 15 Feb 2013 Location: Nottingham Posts: 108 ![]() ![]() ![]() |
My over cooling issue has returned again. I had a blip a few months back where it ran cooler than the usual 88 degrees. Last night driving 80 miles on the motorway it was at 67 degrees! I can't beleive I am so unlucky that the thermostat has failed again within 9 months. Could a faulty pre-heater contribute to it not reaching the correct temperature perhaps? I wondered if the coolant sensor was misreading but when I have the heating at full temperature its not as hot as it should be.
I swapped the thermostat today. The one removed (cheap one from euro car parts) had failed, the metal spring loaded disc that should seal the water way, was at an angle preventing a seal then snapped as I fiddled with it. I sourced a proper LR/BMW replacement from duckworths this time and after the ordeal of stripping it all down again, it is now heating to the correct temperature. That's the third time in 9months I have done that job! The lesson is don't use cheap parts on tricky jobs. 2012 4.4TDV8 VSE
Good job Triple 6 |
Bofa Bill Member Since: 04 Apr 2013 Location: Poole + Rugeley Posts: 174 ![]() ![]() ![]() |
Hi Joe,
Here is the link to my howto for the main thermostat ( I see you found this!)
Weil did the stat today, 3 hrs (no viscous) and only held up once by one of the torx bolts that hold the stat in place.
Mmmmmm 200 miles AND...........
Sounds like the stat is stuck open. Might need a few cycles to free it otherwise it will need to be replaced. Temp guage should be rock solid at 12. .
Hey Bofa Bill
Thanx for that Joe.
Update.
