Home > Maintenance & Mods (L322) > HOWTO: Change Thermostat on '02 TD6 FFRR
Page 2 of 4 <1234>
@ richcl, stan and 666tur
Do you mean the EGR thermal valve?
Cannot find any mention of another "thermostat" .
Post #172736 16th Feb 2013 8:02pm
666tur
United Kingdom 2012 Range Rover Vogue SE TDV8 Zambezi Silver
Yes that's it. The BMW websites call it a thermostat. I replaced that today as well as the main stat. According to the bmw forums they can fail and effect running temps. To test remove and try to blow through, if it blows throug easily when cold then it is stuck open. I bought a new Behr one today and when you try to blow through there is resistance.
Post #172739 16th Feb 2013 8:16pm
Easier and cheaper chopping the EGR out of the equation altogether Thumbs Up
Post #172752 16th Feb 2013 9:14pm
666tur
Worth checking if your cars running too cool and an easy swap. A lot of info BMWland.co.uk
http://www.bmwland.co.uk/forums/viewtopic.php?f=1&t=118248
Post #172828 17th Feb 2013 2:01pm
^^^^^ Excellent link 666tur Bow down .
Post #172833 17th Feb 2013 2:22pm
666tur
Glad it was of use. Can't believe some guy bothered to create a CAD model!
Joe90, When you rebuilt yours did you have any teething problems? Been for another test drive today hoping the vibration was oil in the viscous unit resettling but still have a deep thrum, vibration at 3,000rpm plus.
My niggling worry is I have somehow damaged the water pump, getting the fan off was a pig, it needed a pick axe handle pushing down on the spanner with me practically in the engine bay. The nuts were starting to round, really badly seized.
I will run it this week and see if I can get a helper to rev it while have the bonnet up, then strip it down again next weekend!
Post #172868 17th Feb 2013 6:39pm
Jr-auto-electrics
England 2004 Range Rover Vogue Td6 Java Black
I have the same problem as joe
I changed my thermostat last year and it was better but it is still taking time to reach full working temp
But mine will cool down if I go down hill, but only if I haven't reached full working temp
But If i get it up to temp then roll down a big hill the temp gauge will not drop
So ill try changing that egr stat Thumbs Up RANGE ROVER 04 TD6
RANGE ROVER ULTIMATE EDITION 2012
UPGRADE.
MK 4 SATNAV
http://www.flickr.com/photos/jrautoelectrics/
Post #172870 17th Feb 2013 6:51pm
666tur
It's a cheap and takes ten minutes, there is a useful video on you tube, search egr BMW 530d. If you have done the main stat I bet that's your problem. Do you monitor the temperatures on the hidden menu to see exactly what's happening?
Tested mine to day and up to halfway within three miles.
Post #172874 17th Feb 2013 6:59pm
@666tur
No problems after refit with noises you indicate.
Suggest you remove the "vicious" fan and then run the car (this is perfectly OK, some have it removed all the time), see if the noise is still there. My initial thoughts are that something is out of line with the fan, but could be water pump related?
Regarding egr thermal valve, after fitting the new main thermostat I ran at temperature with no issues, however this was done at a time when we had very warm weather for the time of year so no cold snaps to induce downhill cooling. IIRC I did somehow break a couple of legs off part of the egr thermal valve when I removed it (the black plastic bit at the right hand end) so it could be that it is just not working as it should be, even if the main valves are doing their thing. Will be adding it to my Duckworths shopping list! .
Post #172888 17th Feb 2013 7:51pm
666tur
I was thinking the same, remove the fan and see if the noise is still there. I cant see how i could have damaged the fan itself, it went back on easily, cant imagine it was a cross thread causing the imbalance. I am wondering if I have damaged/bent the shaft of the water pump when I was struggling to get the fan off. It looked a bit tight down there to get the pump off, that will be another fun weekend. At least the fan should be easy to remove this time! 2012 4.4TDV8 VSE
2004 TD6 132k miles- SOLD
1995 Land Rover Defender 110 Tithonus Ex Military
1995 Land Rover Discovery 3.9i V8 manual
Post #172943 17th Feb 2013 11:51pm
Jr-auto-electrics
Poped out the EGR Thermostat tonight only to find that it's passing air and doesn't return back shut once it warms up
New one ordered off eBay £38 inc delivery
Instead of £48 from land rover
Lets see what happens when fitted Thumbs Up RANGE ROVER 04 TD6
UPGRADE.
MK 4 SATNAV
Post #173187 18th Feb 2013 8:05pm
666tur
Have you fitted the new egr stat yet?
Keen to hear if it did the trick. 2012 4.4TDV8 VSE
Post #173665 20th Feb 2013 10:49pm
Jr-auto-electrics
It arrived tonight but I was late getting home
So it's a job for Friday,
Ill keep you posted on what happens RANGE ROVER 04 TD6
UPGRADE.
MK 4 SATNAV
Post #173670 20th Feb 2013 11:06pm
666tur
Update: seven months in from the thermostat changes I am again getting low coolant temperatures. After my 15 mile commute on a mix of rural and city driving I am only getting 76*c on the hidden menu readout. All I can assume is the main thermostat or egr thermal valve has failed again. Very annoying because its not a quick job, I will monitor but it looks like I will be doing it again but this time I think I will use genuine parts. 2012 4.4TDV8 VSE
Post #209090 9th Sep 2013 6:53pm
Stormin
2003 Range Rover HSE Td6 Epsom Green
Can some one tell me how I access the "hidden menu".
I don't have the problem with the needle moving whilst going up and down hills, it just never seems to get to the half way mark Three things in a blokes life his dog,his car and a Cornish pasty,nothing else matters.
2010 Range Rover Vogue SE Santorini Black, Arabica Aniline seats
Previous cars
1973 Mini 1000
1971 Hillman Avenger
1975 Chrysler Sunbeam
1981 Ford Cortina
1985 Volvo 340
1989 VW Golf
1989 Volvo 240
1991 Volvo 240
1991 Jaguar Soveriegn
1996 BMW 730
2003 Honda CRV
1999 Jaguar Soveriegn
2003 Range Rover HSE Epson Green with Sand trim.
Post #209099 9th Sep 2013 7:45pm
Page 2 of 4 <1234>
