Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A ***
Page 19 of 49 <123 ... 181920 ... 474849>
Thought it might be useful to post fault codes / diagnosis (from Patrick - GAP) from my FFRR
Faults Stored 25/11/12:
1.�5C Passenger Door Central Locking Mechanism Short Circuit (no issues obvious, all works as it should)�
Leave it alone since there is no issue.
2. �3505 Unknown (Engine)
Glow plug relay failure - glow relay defective. This one should be investigated if your engine is hard to start when cold.
3. �0404 Unknown (Engine)
Extended fault path exhaust gas recirculation governor deviation - negative deviation. EGR blanked? No?
4. �8A Air Suspension System Can Error (no issues I am aware of)�
CAN errors are normal, ignore them if there is no issues with the system.
5. 41 Park Heater Message Disturbance (see also 0402 below)
0402 FBH Metering Pump Short Circuit to Ground (attempted setting Park Heating, FBH seems to have stopped working now) Included in this e-mail is the wiring diagram of the FBH. Your problem is related to your fuel pump, the output that controls it or the wring. The first thing to verify is the connection between the pump and the FBH itself (C0926-6 and C0920-1). Using a millimeter or asking a mechanic to do so, verify the continuity between the 2 points and if the pump is powered when the FBH is active. You may need to clear faults of the FBH before trying to start it.
6. BD EBV Function Fault Received from ABS ECU (this came straight back after clearing all faults).
We�ve seen this fault on other vehicles also. It may disappear after a while (when a clear fault is done of course). Check your ABS ECU�s fault to see if there is something in there, if not, leave it alone.
7. �BF Instrument Pack Checksum Incorrect (?)�
This error will not affect the functioning of the IPC and can be left alone. Did you check the fault before and it wasn�t there or did it appear after a diagnostic session with a T4? This can sometimes happen when a configuration is changed inside the IPC. To solve this, you can change a configuration (for example, Park Heating) in the IPC Car Config function. Come back to us with the results if you decide to try.
8. 57 Air Suspension active/inactive (?)
This will appear when the suspension has become inactive at one time or another. If everything is sound about your EAS, clear it and leave it alone.
9. 8E and 8F Right/left Side Marker defective (works fine, are these little ones on the wing or the sidelights? I do have LEDs in the sidelights)
Your LED�s are causing these faults. The LCM thinks the lights are burned out since the current draw is significantly lower than with incandescent lights.
10. 23-Key 2 random code tolerance increased (no problems with my only key)
We�ve seen many RR with this errors including our 2005, nothing to worry about.
11. �Transfer Box Current Range BET_N_H (what does this mean?)�
This is the live value of the transfer box gear or range selection. BT_N_H = between neutral and high range. If you move the vehicle, it should change to high range. It can be in between when the vehicle is not moving and a change is done. Didn't change when I moved the car?
Ran fault reading again today 02/12/12
Faults 1,2,3,5,6,7,9 & 10 were there again, but two exciting new ones Smile
LCM 0093 & 0094
Post #154897 2nd Dec 2012 4:16pm
JohnnyDangerous
England 2002 Range Rover Vogue 4.4 V8 Java Black
Might be a stupid question but whats nav on the move? Also can this tool 'turn off' the post CAT O2 sensors? One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #157955 17th Dec 2012 4:12am
some nav firmware versions have the ability to enter destinations whilst moving ,others have it dis-abled , the IIDTool will let you enable it ..
dont think the o2 sensors can be accessed.. ... - .- -.
Post #157960 17th Dec 2012 9:09am
as a few you you have/are getting this unit i thought i would bump this thread up the list as its got lots of questions and many answers... ... - .- -.
Post #163421 10th Jan 2013 6:53pm
mjdronfield
OK, activated the tool........
......trying to enable park heat, done it in 2 places, and from reading this thread, need to do an instrument cluster reset.
How can you do this via the hidden menu ? Don't realy want to disconnect battery.
Is there a fuse ?
I see this on the net ;
Instrument Cluster Tests
Ignition key must be �off�.
� Press and hold the Check Control button in the instrument cluster (RIGHT button), and turn the ignition key to the first position (KLR).
* You will first see "Check Control OK", some seconds later you will see "Test Nr.01"
* Push the left button on the instrument cluster to see the car's identification number. Add the 5 digits (not 6) together and write down that number, you will need it for unlocking all the functions. Example: A123457 will lead to 2+3+4+5+7 = 21
* Push the right button until you see "Test Nr.19"
* Push left button until you see the number that is equal to the one you calculated above
* Push right button again
1. Display Car's identification number, HW/SW version, construction date
2. instrument cluster self test. Will light up all lights and run all guages
3. Current consumption (liters/hour)
4. Average consumption (liters/100 km)
5. Current range
6. Remaining fuel in tank. Three sets of numbers: A/B/C. C=total amount.
7. Engine RPM / Coolant Temp (C)
8. Current Speed (kph)
9. System voltage at Term. "R" (Battery Voltage)
10. Country/Language (UK, US, Spa, Ger, Jap, etc.)
11. Units am/pm
12. Average Speed
13. ETA
14. Date of Software Mask
15. Production Diagnosis
16. ""
17. Display Vehicle Specific Data
18. Alarm Changeover (cont. vs. intermittent OBC chime)
19. Lock/Unlock
20. Correction factor for fuel consumption (nicht �ndern!)
21. Reset all defect codes
Don't see a reset option ? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #163513 10th Jan 2013 10:04pm
I must have missed that step too. Did a change in two places and read I might have to wait a week for things to appear. Been waiting months. Now I find there is a cluster reset to do too. This needs to go in the manual Mr Mfr Wink .
Post #163527 10th Jan 2013 10:29pm
mjdronfield
........and what's FBH Mode ? mine says KBUS 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #163531 10th Jan 2013 10:31pm
SteveMFr
Site Sponsor
Yes Mr. 90, we are working on it. Have you ever written a book? Wink Laughing
Test Nr. 21 is 'Reset'. I've seen the 'Reset all defect codes' on the net here and there too - it ain't so. Otherwise people wouldn't be touching battery terminals, etc (which doesn't work for clearing faults either, BTW) or having to buy diagnostic tools Cool . 'Reset' is a cluster reset. The cluster acts as a gateway between the iBus where the nav screen lives and Kbus where the FBH is, so you need to make sure the changes have taken effect just as you would with a PC that you've made sw changes to. Do a Nr. 21 - and then please let us know if all is good.
Joe, I saw that you mentioned in another thread that you have a prob with your EAS that won't go away (RF IIRC?). Can you describe more closely?
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #163578 11th Jan 2013 8:44am
cliffy
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
I've looked at all cons, hawkeye etc and I've decided to go with the IIDTool
I've sent a price enquiry to Brittany last night
Post #163630 11th Jan 2013 11:21am
cliffy
Still no reply from Brit Part on a price, ive seen what LRP want for one but im hoping Britpart can do better, still cant believe they havent replied yet
Post #163688 11th Jan 2013 2:37pm
SteveMFr
Site Sponsor
I was wondering who Brittany was... Laughing
Cliffy, Britpart will not give you a price. They are only wholesalers and the dealers are left to make their own prices. They will only give you an address to a dealer local to you.
If you are looking for the best price, I suggest you google IIDTool + Price. You'll get a couple of hits to online dealers on the first page. One of them, who sells LR Parts Wink Wink, has the best prices that I know of.
We are not supposed to recommend specific Britpart resellers either due to favoritism, so I can't do better than that. Sorry.
There have also been price discussions here on the board. Maybe someone can chime in...
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #163729 11th Jan 2013 4:25pm
So just to confirm (re Park Heat) we use the IIDtool in two places (OTTOMH I can't remember where), then do the No. 21 Reset, and hopefully Park Heat will show up?
Regarding my EAS issue, I have been in touch with Patrick about it from the beginning, who has been very helpful, but not had the chance or inclination to play with the setup since then. Seems that (and I had the problem with the All Comms too) my front left won't respond to individual height changes, no matter what I throw at it. If I run the set front heights, both will go up and down, but the front left always stays @ 10-15mm lower than the front right. I have tried over-compensating to no avail. IIUC it is the built in EAS computer gremlins that are the problem, or my front left height adjuster (despite no faults) requires replacing. .
Post #163742 11th Jan 2013 5:08pm
mjdronfield
Well wait no more Mr 90 !!
I've just enabled Park Heat !!!
On the main menu it still says Aux Ventilation, but if you select it, I now have Aux Heat and then Aux Vent.
Now am I brave enough to try it ?
May do two 9's on my phone, then I'll only have to do another one for the Fire Brigade !!
If I remember right Joe, Park Heat needs to be set to active / enabled under the Fuel Burning Heater and the Instrument Pack section, on the IID Tool.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #163799 11th Jan 2013 7:03pm
The Brains Trust
Australia 2003 Range Rover HSE Td6 Adriatic Blue
Small issue
Went to use my IID tool today and it isn't working as it did last time. I originally plugged it in to see if I could reset the INSPECTION light that is on when the ignition is first turned on. I couldn't find anything that would do this, so I thought I'd see what faults had developed in the last couple of months. Turns out I couldn't see most of the ECU's including the engine, gearbox, etc. tried to do a fault reset - RESET ALL and it goes through to 10, then comes up with UPDATE FAIL, then exits the tool.
Tried a few times and it always does the same thing - any ideas - including how to reset the INSPECTION lamp? I have also tried to do this using the buttons on the dash, but no luck with that either.
Cheers - Gav
Post #163939 12th Jan 2013 10:23am
SteveMFr
Site Sponsor
Hi Gav,
Not seeing most of the ECUs is usually when you try to use the IIDTool in Accy position. Numerous ECUs, such as the engine's are 'asleep' so they are not seen.
You have an 03, the SIR is done via the dash buttons - not a diagnostic tool. Only the later RRs do this via a diagnostic system and they can't have it done via the dash buttons. So count yourself better off. Laughing
Model Chassis Model year
Discovery 3 / LR3 L319 2005 to 2006
Range Rover L322 2002 to 2004
Range Rover Sport (not supercharged) L320 2005 to 2006
Procedure to check/reset service status
- Switch ignition OFF
- Press and Hold left instrument panel reset button, switch ignition to position 'I' (accessories)
- Keep reset button pressed for approximately 5 seconds until the LCD displays 'RESET SIA'. The
distance to service (e.g. 2150 miles) and the service type (e.g. Inspection/oil service) will be
displayed.
- Has the 'Reset Distance' limit been reached or exceeded?
o NO - Follow instructions in section 2 below
o YES - Follow 'Reset Distance Counter' instructions below
Sec 1: Reset Distance counter procedure
- Press and hold left instrument reset button for 5 seconds. 'RESET' will begin to flash on the LCD
display.
- To reset distance the left hand button should be pressed before the 'RESET' message has flashed 5
times
- The LCD will display 'END SIA'. Switch ignition off
Sec 2: Procedure to check/reset service status - Date counter
- Press left instrument panel reset button once
- The LCD will display 'RESET SIA' followed by the service due date.
- Has the 'Reset Date limit been reached or exceeded?
o NO - Press the left instrument button once. The LCD will display 'END SIA' to indicate the
service interval check/reset procedure has been cancelled.
o YES - Follow 'Reset Date Counter' instructions below
Reset Date counter procedure
display.
times
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #163941 12th Jan 2013 10:59am
