![]() | Home > Maintenance & Mods (L322) > LED Bulbs |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
Just found these on ebay - might give them a go
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 ![]() ![]() |
Not sure they'll be that good to be honest noddy.
andyw Member Since: 15 Oct 2009 Location: united kingdom Posts: 160 ![]() ![]() ![]() |
give these guys a ring they do white with 4 looking forward 13 quid inc post worth a try |
RRCanuck Member Since: 23 Dec 2009 Location: Ontario Posts: 172 ![]() ![]() ![]() |
Nice job Steve R. |
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 ![]() ![]() ![]() |
How about these http://cgi.ebay.co.uk/8-LED-NO-CANBUS-WARN...1e5b227d26 ?
They're what I'm using, if any worries come MOT time, just swap them for normal bulbs. Can't see how they would fail though, you can't really see that there's 4 seperate LED's...
just bought some fitted went out in the dark to see how bright and when i switched the ignition on to just before start they flash alternatively then every few seconds any one else got this and is it the self check puting a current through to check a full back emf 02 Range Rover HSE Zambezie silver 4.4 |
SGW Member Since: 09 Sep 2009 Location: Headcorn Kent UK Posts: 77 ![]() ![]() ![]() |
Yes mine flicker like this, even though I have turned off the self check module.
dantheman Member Since: 02 Feb 2009 Location: North: Lancs Posts: 477 ![]() ![]() |
Yeah, fitted some that arrived from ebay also - ![]() Ho hum. Back to the drawing board! ![]() |
Well, mine arrived today and they're crap! Having said that, I need to see them at night to see how bright they are. Not holdign my breath though! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
I tried the ebay canbus ones http://cgi.ebay.co.uk/8-LED-NO-CANBUS-WARN...1e5b227d26 and they are bright enough and match the HID headlight colours. Hopefully they won't fail the MOT either ! |
jayzee Member Since: 14 Oct 2009 Location: UK Posts: 342 ![]() ![]() |
Which ones did you buy Noddy? Java with Ivory 2006 4.2 Supercharged. 23.5k miles - NOW SOLD! |
The ones in my earlier post above (ebay link).
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
Has anyone successfully fitted some non-error numberplate LED's ? Is this where I put the car details and a bit about myself ?........ |
