Home > Technical (L322) > Engine light on
tony1kenobee
England 2003 Range Rover Autobiography 4.4 V8 Zambezi Silver
Engine light on
Hi all,just been driving down from Bicester and the engine management light flashed and came on.whenever I put my foot down I had little or no response from the car.at low speed seems ok.i had tied to do kick down to overtake and nothing happened.im running a 4.4 v8 2003 l322 on LPG.this is probably a bit vague in description just wondering if anyone had ideas.also I'm in Southampton does anyone know a good garage I could pop into to have the engine read by the gizmo they use to diagnose issues.kindest regards in advance to anyone who replies. Tony
Post #160088 26th Dec 2012 8:44pm
JAYBOY
Sounds like the car went into limp mode.
Did you try and stop the car then restart it.
Does the light come straight back on. 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 JCW Mini Cooper
2018 Skoda VRS
Post #160089 26th Dec 2012 8:49pm
BrianC
Can you run the car without LPG ? And see if it clears, I'm not sure if you can do that as I've never had LPG
Post #160090 26th Dec 2012 8:56pm
tony1kenobee
I havent tried to run without LPG ,will give it a go in the morning.i did stop and fuel up,both LPG and petrol .the light came back on and has stayed on ever since.
Post #160091 26th Dec 2012 9:01pm
JAYBOY
Did the light come back on with ignition and stay on or did come back on when you started to drive again. 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 Skoda VRS
Post #160092 26th Dec 2012 9:07pm
tony1kenobee
It came on withe ignition and stayed on.
Post #160093 26th Dec 2012 9:10pm
JAYBOY
There are a few specialists in Southampton when you do a google search.
Sorry can't recommend any but i think you've just got to go with who's open tomorrow.
Good luck 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 Skoda VRS
Post #160094 26th Dec 2012 9:19pm
tony1kenobee
Many thanks for your input.im sure ill find someone.brooklyn 4x4 looks ok.just not keen on main dealer.regards tony
Post #160096 26th Dec 2012 9:22pm
JohnnyDangerous
England 2002 Range Rover Vogue 4.4 V8 Java Black
The lpg has prob killed one or both cats and maybe an O2 sensor, if its killed the rear sensors not too much of a problem if its the fronts it will be, you need to plug a decent diagnostic machine on and monitor the O2 sensors, mine has no cats and the rear O2 sensors play up, we have sonme kit that can remove the rear sensors from the ecu, will get on it after xmas and report back. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #160112 27th Dec 2012 3:13am
oliver9627
United Kingdom 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
Does LPG kill cat converters then? When I start mine when it is cold there is a rattling noise, someone said it sounded like a cat converter. It does not do it as bad when warmed up, can I do away with them, or is it best to replace them? Gone:
Golf GT TDI 150- Still got.
BMW 325TD
Range Rover Classic
Defender 90
Post #160124 27th Dec 2012 9:44am
LPG killing cats is a new one on me Shocked I would hope it doesn't as they are expensive to replace. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #160134 27th Dec 2012 10:20am
Censored Censored Censored signal repost [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #160135 27th Dec 2012 10:21am
Clousta
Belgium
I have been driving on LPG since late 2000. 3 SAABs (2 turbo charged) and a P38. Never had any problems with the catalytic converters or the Lambda probes and certainly no ill effects from running on LPG. Exhausts last a great deal longer on LPG and I would expect the catalytic converters to do so too. 1998 RR 4.6 HSE lpg
Rovacomlite (all modules for a '98 GEMS P38, except Cruise Control). EAS Kicker (P38 & RRC)
Post #160142 27th Dec 2012 10:59am
That's what I thought. Hadn't seen anything about that when I was researching LPG before I took the plunge. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #160144 27th Dec 2012 11:13am
steptoe
JohnnyDangerous wrote:
The lpg has prob killed one or both cats and maybe an O2 sensor, .
What are you rambling on about Mr. Green
Post #160149 27th Dec 2012 11:58am
