Home > Technical (L322) > Engine light on |
tony1kenobee Member Since: 07 Jul 2012 Location: SOUTHAMPTON Posts: 145 |
Hi all,just been driving down from Bicester and the engine management light flashed and came on.whenever I put my foot down I had little or no response from the car.at low speed seems ok.i had tied to do kick down to overtake and nothing happened.im running a 4.4 v8 2003 l322 on LPG.this is probably a bit vague in description just wondering if anyone had ideas.also I'm in Southampton does anyone know a good garage I could pop into to have the engine read by the gizmo they use to diagnose issues.kindest regards in advance to anyone who replies. Tony |
26th Dec 2012 8:44pm |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 |
Sounds like the car went into limp mode.
26th Dec 2012 8:49pm |
BrianC Member Since: 15 Apr 2009 Location: central belt Posts: 1429 |
Can you run the car without LPG ? And see if it clears, I'm not sure if you can do that as I've never had LPG |
26th Dec 2012 8:56pm |
I havent tried to run without LPG ,will give it a go in the morning.i did stop and fuel up,both LPG and petrol .the light came back on and has stayed on ever since. |
26th Dec 2012 9:01pm |
Did the light come back on with ignition and stay on or did come back on when you started to drive again. 2020 Porsche Panamera Turbo Hybrid (V FAST)
26th Dec 2012 9:07pm |
It came on withe ignition and stayed on. |
26th Dec 2012 9:10pm |
There are a few specialists in Southampton when you do a google search.
26th Dec 2012 9:19pm |
Many thanks for your input.im sure ill find someone.brooklyn 4x4 looks ok.just not keen on main dealer.regards tony |
26th Dec 2012 9:22pm |
JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833 |
The lpg has prob killed one or both cats and maybe an O2 sensor, if its killed the rear sensors not too much of a problem if its the fronts it will be, you need to plug a decent diagnostic machine on and monitor the O2 sensors, mine has no cats and the rear O2 sensors play up, we have sonme kit that can remove the rear sensors from the ecu, will get on it after xmas and report back. One day your life will flash before your eyes......................................make sure yours is worth watching!
27th Dec 2012 3:13am |
oliver9627 Member Since: 25 Oct 2012 Location: Chipping Norton Posts: 51 |
Does LPG kill cat converters then? When I start mine when it is cold there is a rattling noise, someone said it sounded like a cat converter. It does not do it as bad when warmed up, can I do away with them, or is it best to replace them? Gone:
27th Dec 2012 9:44am |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
LPG killing cats is a new one on me I would hope it doesn't as they are expensive to replace. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
27th Dec 2012 10:20am |
signal repost [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
27th Dec 2012 10:21am |
That's what I thought. Hadn't seen anything about that when I was researching LPG before I took the plunge. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
27th Dec 2012 11:13am |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 |
What are you rambling on about |
27th Dec 2012 11:58am |
