Home > Technical (L322) > Car doesn't try and start? |
JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833 |
On an ordinary car I would say ignition switch faulty but on the RR it could be different, it seems mine has always had like a delayed reaction, I can turn the key and release it and the car will start almost after Ive released the key. Does it have an ecu for the ign switch? it has an ecu for everything else. One day your life will flash before your eyes......................................make sure yours is worth watching!
26th Dec 2012 4:48pm |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 |
Whenever this happens to me its because the gear selector is not fully in park. |
26th Dec 2012 5:34pm |
Paulhh Member Since: 23 Dec 2012 Location: Carrbridge Posts: 143 |
I think the car was fully in park, certainly couldn't move it until the car fired up. I've had this RR for about a week so slowly getting used to it but there has been a few times it didn't fire first time but this morning it may have been 6 or 7 times before firing, meanwhile steering wheel is going in and out like a yo yo. |
26th Dec 2012 6:15pm |
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 738 |
Mine was similar
26th Dec 2012 6:24pm |
Excellent comment Johnte, read the link and I'll target the Ignition switch if it stays the same, how long did it take to remove? |
26th Dec 2012 6:30pm |
Yours sounds just like mine was. To start with, only did it very occasionally, but got worse and worse for a couple of months, then one day wouldn't start at all...
26th Dec 2012 7:29pm |
Cheers for the update. Takes away the fear when you have a little info on these things. I guess there isn't any coding or anything and it's just a straight swap for a new ignition switch. |
26th Dec 2012 7:32pm |
RCusden Member Since: 12 May 2012 Location: NarberthPembrokeshire Posts: 186 |
If the ign switch is okay check for voltage at the starter on the small terminal to check all wiring and the immobiliser is all working ok
26th Dec 2012 7:48pm |
I just unplugged the old switch, plugged the new one in and cured - been OK ever since
26th Dec 2012 7:54pm |
Cheers mate, your help is greatly appreciated |
26th Dec 2012 9:33pm |
