Home > Technical (L322) > Car doesn't try and start?
Paulhh
Scotland 2002 Range Rover Vogue 4.4 V8 Epsom Green
Hi Folks
Does anyone know why sometimes when I insert the key and turn it, the car doesn't try and start? I hear the immobiliser going off then turn the key so everything lights up then turn fully but no turning of the engine. Obviously this turning of the key is one complete fluid motion.
Post #160053 26th Dec 2012 3:15pm
JohnnyDangerous
England 2002 Range Rover Vogue 4.4 V8 Java Black
On an ordinary car I would say ignition switch faulty but on the RR it could be different, it seems mine has always had like a delayed reaction, I can turn the key and release it and the car will start almost after Ive released the key. Does it have an ecu for the ign switch? it has an ecu for everything else. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #160055 26th Dec 2012 3:48pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Whenever this happens to me its because the gear selector is not fully in park.
Post #160063 26th Dec 2012 4:34pm
Paulhh
I think the car was fully in park, certainly couldn't move it until the car fired up. I've had this RR for about a week so slowly getting used to it but there has been a few times it didn't fire first time but this morning it may have been 6 or 7 times before firing, meanwhile steering wheel is going in and out like a yo yo.
Post #160071 26th Dec 2012 5:15pm
Johnte
Mine was similar
http://www.fullfatrr.com/forum/topic14442....ion+switch
Post #160072 26th Dec 2012 5:24pm
Paulhh
Excellent comment Johnte, read the link and I'll target the Ignition switch if it stays the same, how long did it take to remove?
Post #160073 26th Dec 2012 5:30pm
Johnte
Yours sounds just like mine was. To start with, only did it very occasionally, but got worse and worse for a couple of months, then one day wouldn't start at all...
Replacement switch was around £90 including VAT from local main dealer (supply only). I fitted in myself in about 1/2 hr Thumbs Up
Post #160077 26th Dec 2012 6:29pm
Paulhh
Cheers for the update. Takes away the fear when you have a little info on these things. I guess there isn't any coding or anything and it's just a straight swap for a new ignition switch.
Post #160078 26th Dec 2012 6:32pm
RCusden
Wales
If the ign switch is okay check for voltage at the starter on the small terminal to check all wiring and the immobiliser is all working ok
Roger
Post #160079 26th Dec 2012 6:48pm
Johnte
I just unplugged the old switch, plugged the new one in and cured - been OK ever since Thumbs Up
If you do find you need a starter, I have a good used one in stock Whistle
(bought a new one, thinking the old one was faulty Big Cry )
Post #160082 26th Dec 2012 6:54pm
Paulhh
Cheers mate, your help is greatly appreciated
Post #160086 26th Dec 2012 8:33pm
