![]() | Home > Technical (L322) > front parking sensors |
BOBCUSSEN Member Since: 25 Nov 2012 Location: DORDOGNE Posts: 296 ![]() ![]() ![]() |
hi All, my front sensors have suddenly stopped working. |
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 743 ![]() ![]() |
Have a look here -
GJOB Member Since: 24 Oct 2010 Location: Northants Posts: 131 ![]() ![]() |
It's easy to diagnose:
wanderer Member Since: 10 Nov 2012 Location: Wandering Posts: 178 ![]() ![]() |
A dealer is currently replacing one of mine and said that the replacement will need spraying up in body colour. Is that correct, do replacement sensors need spraying? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
If you want them to match. Don't think you can get replacement sensors in "all" colours. If you need to know for sure check with Duckworths Dan. .
hi archie, no it is not really icy. infact very mild at around 16 degrees at the mo. i will listen at the front and see if i can hear anything clicking? with regard to switching them on, i assume i just turn on the ignition and put it in drive to test them |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
Leave it in park. There is a button, bottom left, to switch on the park sensors. |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
When I lost the front sensors, it was the PDC ECU in the boot that needed to be replaced. |
ok mate, i did know about the button but just thought that used if you wanted to keep them on whilst driving |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
On mine (2007MY) that will not activate the fronts, reverse has to be selected or switch pressed before system is switched on |
yes, when i start, i jus put in reverse and on comes the light and the rears are working, when i pull forward, up until they stopped, the fronts came on without having to do anything else. when i start driving, after a short while the light goes off. i guess i will just do the checks as i expect it is either the sensors themselves or the rear ecu
