Home > Maintenance & Mods (L322) > Reversing Light Replacement
Just a quick note for those with cracked lenses or discoloured/aged lenses you can get brand new full units that take 2 minutes to fit from Dan @ Duckworths:
£26inc vat, XFD000043
They really make the back end look a lot newer on older cars Thumbs Up
Post #157577 15th Dec 2012 10:42am
thanks for the heads up Gary...and whilst you're replacing the lens you can fit led bulbs as well.. ... - .- -.
Post #157582 15th Dec 2012 11:51am
Link Stan ! .
Post #157588 15th Dec 2012 12:16pm
link?...they are bog standard 501's if memory serve me well.... ... - .- -.
Post #157594 15th Dec 2012 12:37pm
Took pictures of my reversing bulbs today. was expecting "festoon types"?
Post #157629 15th Dec 2012 4:22pm
H6 halogen and pretty useless with it.
To date I haven't found any led fittings to replace them that would work.
Post #157633 15th Dec 2012 4:32pm
A1GSS
You could try Disco3 Site Sponsors HIDS4U:
http://www.hids4u.co.uk/home.php Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #157637 15th Dec 2012 4:52pm
On the bay
http://www.ebay.co.uk/itm/2x-5-SMD-LED-433...43af33d018
but not canbus ready.
C'mon stan Wink .
Post #157640 15th Dec 2012 5:05pm
A1GSS
Don't think the CANbus plays any part in the light bulbs...? Graham
____
Post #157642 15th Dec 2012 5:15pm
Sure does, without canbus ready bulbs, or fitting resistors, the car throws an error on start up to advise bulb is broken! .
Post #157645 15th Dec 2012 5:19pm
Yes, you need canbus leds they display on the message screen otherwise.
The problem with led bulbs in the reverse light fittings is that they are generally too long and simply don't fit.
Post #157646 15th Dec 2012 5:22pm
Possible this might be another LED strip job. I reckon the lens will come away from the backing in much the same way as the reflectors. Then drill small hole at bottom of backing piece for wires, stick two short White LED strips either side of the bulb housing, wire up to original wires, glue lens back on. Just a matter of whether this is bright enough? .
Post #157658 15th Dec 2012 6:12pm
