Home > Maintenance & Mods (L322) > Reversing Light Replacement |
Just a quick note for those with cracked lenses or discoloured/aged lenses you can get brand new full units that take 2 minutes to fit from Dan @ Duckworths:
15th Dec 2012 10:42am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35373 |
thanks for the heads up Gary...and whilst you're replacing the lens you can fit led bulbs as well.. ... - .- -.
15th Dec 2012 11:51am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Link Stan ! .
15th Dec 2012 12:16pm |
link?...they are bog standard 501's if memory serve me well.... ... - .- -.
15th Dec 2012 12:37pm |
Took pictures of my reversing bulbs today. was expecting "festoon types"?
15th Dec 2012 4:22pm |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 |
You could try Disco3 Site Sponsors HIDS4U:
15th Dec 2012 4:52pm |
On the bay
15th Dec 2012 5:05pm |
Don't think the CANbus plays any part in the light bulbs...? Graham
15th Dec 2012 5:15pm |
Sure does, without canbus ready bulbs, or fitting resistors, the car throws an error on start up to advise bulb is broken! .
15th Dec 2012 5:19pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
Yes, you need canbus leds they display on the message screen otherwise.
15th Dec 2012 5:22pm |
Possible this might be another LED strip job. I reckon the lens will come away from the backing in much the same way as the reflectors. Then drill small hole at bottom of backing piece for wires, stick two short White LED strips either side of the bulb housing, wire up to original wires, glue lens back on. Just a matter of whether this is bright enough? .
15th Dec 2012 6:12pm |
