Home > In Car Electronics (L322) > Phone disconected-solved
Norway
Norway 2003 Range Rover Vogue Td6 Adriatic Blue
I all,this is my first post sow I great you all.
"Howcan I get my phone activated or working."
I have a03 Vogue that had a mk3 satnav with phone and voice recognition.
Thephone settings were active but due to no sim card I could not use the phone.
I purchaseda mk4 satnav and installed this unit successfully, but it did not detect myphone. At least did the phone not turn up in mfd meny.
Not beingsure what do to I got hold off an extra sim but that did not alter the situationafter it being inserted to the sim card slot.
Then I dida successfully satnat update to the latest sw4-1/(1)00 (vs 32). The phone didnot turn up in the satnav.
Thevoice recognition does not work anymore either. When i press the phone button on the mfd nothing happens.
br
Post #156239 9th Dec 2012 10:57am
Hello and welcome. Thumbs Up
Sorry for obvious, but have you tried checking all connections? If you put the mk3 back in does everything work again? Might be worth a try now you have a sim. Previously..
Post #156240 9th Dec 2012 11:19am
Norway
Hi
Thx for your superfast reply.
I did change back to the mk3 unit and for some small period i had the telephone option at the screen. The option was not acessable and cleared out after a minute.
Iw cheked the two connections on the simens unit in the back trunk, i guess thats the phone unit right.
Iam not sure where the voice rec unit is, or what other connections to check.
Plz advice me.
br Nor
Post #156243 9th Dec 2012 11:27am
mjdronfield
The TCU (phone unit) is mounted vertically in the boot with the 54 pin black connector on top.
The voice control module is mounted underneath the sat nav unit.
The phone unit needs power, an earth and an ibus connection to appear on the screen.
Have you checked fuse 22 in the glovebox, as this feeds the phone unit.........
I don't think changing the nav unit should affect it, but could be wrong.
If you download RAVE from the Wiki, all the wiring diagrams and unit descriptions etc are in there. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #156256 9th Dec 2012 12:32pm
Norway
Hi
I guess i have an other version of the phone and voice rec, unit.
My phone unit is wihtout the black connecgtion on top. What i have on top is a wire that is screwd and a thin wire that is clipped on. I was not able to get pictures uploaded
Post #156268 9th Dec 2012 1:40pm
mjdronfield
I can't see the pictures there as I'm not a registered member, the very small pictures are all I can see.
The voice unit should be under the sat nav. From what I can see from your pic, thats looks like an aerial booster or similar ;
Picture posting instructions ;
http://www.fullfatrr.com/forum/topic1023.html
http://www.fullfatrr.com/forum/topic10245.html 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #156274 9th Dec 2012 2:10pm
Norway
thx
Looks like this ones right
This picture I took from another thread. Do I need to use this black big connection that I to have atm unused.
No phone source deteced.
I cant remember to have seen the voice rec as the picture you posted, but I will have a closer look when the boss is back from shopping. -03V td6
-72 Cadillac Coupe DeVille 7,7liter.
Post #156279 9th Dec 2012 2:33pm
Norway
Sim card, the button is pulled to possition "1"
Overview
 -03V td6
Post #156282 9th Dec 2012 2:38pm
mjdronfield
The big 54 pin plug connects to the phone control unit. Without it, you'll have nothing. The other connections are just aerials I think.
To be fair, I don't have those in my car, I have what you have posted as the 2nd pic, and added units from a later BMW to get bluetooth and voice recognition, so I can't use my car to compare to yours.
Perhaps you don't have voice recognition, though if its worked before, the unit must be somewhere..... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #156283 9th Dec 2012 2:41pm
mjdronfield
The black 54 pin connector goes on the other end of the telephone control module ;
Your phone unit seems to be mounted the other way up to the one in the workshop manual ?
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #156285 9th Dec 2012 2:48pm
Norway
Thx man
Ill do some other hi res pic for you to see, and just maby that help.
Is there a way to flash the phone units or to reactivate them and If there is a wire that is broken, where would this most likely happend? -03V td6
Post #156287 9th Dec 2012 2:55pm
Norway
if this does it your the best. If not i hope i only blow i a fuse.
Btw, iw checked earlier and its not the fuse nr 22 or nr 8 that causes this misfunction -03V td6
Post #156291 9th Dec 2012 2:58pm
Norway
Thx mjdronfield Thumbs Up Rolling with laughter
You did it. The units powered up and works like a charme.
I cant thank you egnuff.
br -03V td6
Post #156300 9th Dec 2012 4:36pm
mjdronfield
Absolutely not a problem.
You are most welcome - to the best L322 Range Rover forum in the world.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #156302 9th Dec 2012 4:47pm
SteveMFr
Site Sponsor
So what was the problem?
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #156327 9th Dec 2012 6:39pm
