Home > General > Going to see one - advice please |
The Flying Scot Member Since: 09 Apr 2009 Location: Surrey Posts: 77 |
Hi Guys
7th Dec 2012 4:50pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7708 |
Always pays to keep a bit back for a gearbox !!
7th Dec 2012 4:57pm |
Thanks for the pointers Martin,
7th Dec 2012 5:27pm |
Ah, sorry, didn't notice your signature. Thought you'd not had one before........
7th Dec 2012 5:58pm |
Well just got back from viewing.
8th Dec 2012 11:09am |
I thought if the pump was on its way out, the system tried to get to the new suspension height you'd requested, and times out after a few mins, then shows a message.
8th Dec 2012 11:17am |
You would have to look at fault codes. It could be all kinds of issues. Small leak in an airbag, the compressor needs overhaul, a valve sticking a bit, temperature (overheating) sensor starting to kick in or malfuction, leak in a hose etc. etc.
8th Dec 2012 11:18am |
Hi, I cycled the car through all the heights positions and it worked fine.
8th Dec 2012 11:24am |
http://www.fullfatrr.com/forum/topic14320.html
8th Dec 2012 11:26am |
mmm..you could be right...
8th Dec 2012 11:40am |
The compressor re-build is not too bad, either the "cheap" way or use the kit Meerbusch is selling. If that is it. If it is airbags, it is a bit more expensive (I just replaced both front struts on mine). But it could also be a simple air hose leak/connector loose. I suggest to get the fault codes read to see what that indicates. And maybe also jack it to off-road height, switch everything off and listen for leaks (in a quiet area/garage). MY 2010 5.0 SC Galway green and sand interior!!
8th Dec 2012 11:58am |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2934 |
I'd barter and quote the cost of a new compressor, then get a repair kit from Meerbusch 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
8th Dec 2012 12:06pm |
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1199 |
I had a similar experience shortly after having bought mine (also an '06 MY car - which I believe have a different compressor to the earlier cars).
8th Dec 2012 1:26pm |
Thanks guys,
8th Dec 2012 2:34pm |
