Home > Technical (L322) > Rear Camera swap
supershuttle
Rear Camera swap
I've got a 2007 and the rear camera is at best OK. I just bought SWMBO a new Nissan Juke (keep your comments to yourself) and the rear camera is loads better. I've read on here people swapping rear cameras but is there a clear performance improvement and what would I need. I will be fitting a new seal in the rear wiper this week or next and so it would make sense to kill two birds etc...
I fairly nifty with a soldering iron so plug changes etc are no problem and I can drill a reasonable hole and make body mods if needed glueing things back together with epoxy.
This is a bit like changing to the flip key from my early 2007 none folding jobbie- needs CLARITY!!
Cheers and thanks for any sensible help Thumbs Up Geoff
Post #152595 21st Nov 2012 7:55pm
Googsy
You can but I think limitation is screen resolution. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #152603 21st Nov 2012 8:06pm
JAYBOY
If you get a reply to this thread. I would like one for mine.
The one on my car is fuzzy at best. 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 JCW Mini Cooper
2018 Skoda VRS
Post #152615 21st Nov 2012 8:36pm
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
I got some improvement from replacing a MY2006 with a My2012, but the problem is that the screen zooms the image regardless of camera year, and this makes it look grainy
Gone - Range Rover Supercharged 2006
Post #152621 21st Nov 2012 8:50pm
JAYBOY
Excuse me for my ignorance but is it the same screen on a MY2006 and MY2007 or did they change them on 07 ? 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 Skoda VRS
Post #152622 21st Nov 2012 8:54pm
JustinP
same touch screen from 2005 through to 2010
Post #152624 21st Nov 2012 8:57pm
JAYBOY
Thanks Thumbs Up 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 Skoda VRS
Post #152625 21st Nov 2012 8:59pm
Ive a 2012 one in mine and its ace!
You would need to re-wire the two plugs and drill a new hole to re-locate the camera further to the right.
You even get parking lines too! Razz
Craig Thumbs Up
Post #152667 21st Nov 2012 11:57pm
nbunney
Any pics / guide and cost Craig Thumbs Up
Post #152700 22nd Nov 2012 9:12am
Unfortunately were one of the unlucky ones with water and flooding everywhere here... Maybe when we get sorted i will sit down and do a how to for the wiki...
Craig Crying or Very sad
Post #152704 22nd Nov 2012 9:32am
Johnte
I fitted a new camera (old one broke) to my 2006MY
The cost for parts was £174.00
Post #152707 22nd Nov 2012 9:46am
DeRanged Rover
United Kingdom 2006 Range Rover Vogue SE Td6 Java Black
Hi Johnte,
Where did you source this from? And did it plug straight in or were there any mods? African Bush Junkie ... in London!
Stats:
2006 TD6 Vogue SE
1972-2015 DeRanged Rover
2001 P38 dHSE (SOLD)
Post #152721 22nd Nov 2012 10:43am
there is this http://www.fullfatrr.com/forum/topic4621.html from our wiki which might help.... ... - .- -.
Post #152723 22nd Nov 2012 10:48am
Johnte
The parts (camera + mount + loom) came from Dan@Duckworths Thumbs Up
For me, it wasn't a straight forward fit ... because the old loom didn't plug straight into the new one Confused (I'm sure if unlike me, you're reasonably electrically / mechanically minded it won't be too bad)
I ended up cutting the plugs off both looms and joining them http://www.fullfatrr.com/forum/topic14197.html?highlight=camera
Although I'm not suggesting you do this, and hopefully someone will be along and tell you how it should be done Whistle
The camera mount on the spoiler, again is slightly different, but not too bad a job with a bit of time and effort.
Post #152726 22nd Nov 2012 11:03am
goldsax
United Kingdom 2011 Range Rover Vogue 4.4 V8 Ipanema Sand
same combo here FF and Juke..
the Juke is fantastic, even in the dark you cannot miss a thing.
the FF is really poor.
looking to take guidence from this thread and change the one on the FF as well.. 2011 4.4 TdV8 Nara Bronze
Post #152728 22nd Nov 2012 11:58am
