![]() | Home > General > Disappointment...... |
How do you drive? if you are heavy on the throttle the mpg you indicate is possible with a TD6. When I bought my Td6 the consumption was reading 13.5mpg which was a bit worrying |
baldylocks Member Since: 05 Apr 2010 Location: Gods Own County Posts: 42 ![]() ![]() ![]() |
I do like to make a bit of progress when I can but I'm not too bad, to give you an idea a Skoda Octavia 4 wheel drive estate wiith the 180bhp Golf GTI engine in it gives me over 30 mpg on the same use.
netsonic Steve Member Since: 06 Oct 2010 Location: Sussex Posts: 165 ![]() ![]() ![]() |
I have a TD6 2002 with 106k, i do regular motorway trips and get 30-32 mpg, |
lrdaft Member Since: 08 Apr 2010 Location: United Kingdom Posts: 60 ![]() ![]() ![]() |
I get 15 to 16 on my supercharged and 19 mpg on a run ,not much in it considering petrol is about 6 p per litre cheaper |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2669 ![]() ![]() |
Last tank used town driving only, average 18! |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 ![]() ![]() ![]() |
Round town? I get about 14, although I do like to "accelerate briskly" |
Yup, all pretty short trips which didn't help! |
here is a nice little fuel calculator
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1199 ![]() ![]() |
CHECK YOUR REAR CALIPERS . . . . .
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3763 ![]() ![]() |
baldylocks, an average of around 28mpg is easily achievable with a TD6, mixed motorway and A roads, a TDV8 will do 30 ime. |
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 ![]() ![]() |
I'm getting 20 mpg out of my 4.4 V8 petrol in normal driving so you should be getting better than 18 mpg.
Aye, I had a jammed caliper, now replaced, we'll see what the next tank does, off to see fisha at the weekend so will report back. |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 ![]() ![]() |
Are you driving your diesel engine like a petrol engine ? |
It takes time to get used to the gearbox and get into the habit of knowning how to force it into a lockup or to stop slipping. this is the best way to yield higher MPG in the TD6 other than flushing the fuel system |
