Home > General > Disappointment...... |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6405 |
How do you drive? if you are heavy on the throttle the mpg you indicate is possible with a TD6. When I bought my Td6 the consumption was reading 13.5mpg which was a bit worrying
20th Nov 2012 8:38pm |
baldylocks Member Since: 05 Apr 2010 Location: Gods Own County Posts: 42 |
I do like to make a bit of progress when I can but I'm not too bad, to give you an idea a Skoda Octavia 4 wheel drive estate wiith the 180bhp Golf GTI engine in it gives me over 30 mpg on the same use.
20th Nov 2012 8:44pm |
netsonic Steve Member Since: 06 Oct 2010 Location: Sussex Posts: 165 |
I have a TD6 2002 with 106k, i do regular motorway trips and get 30-32 mpg, when i get near home and onto A roads it can go as low as 24 mpg, the only time I get 18mpg is if I boot it or have long or steep inclines to drive up. Could be lots of reasons why yours is low but a good start is to ensure the servicing is done regular, I do mine every 6k including filters, air oil etc, also blanking the egr which you can see on Wiki is an easy mod and I also believe changing the crankcase breather for a vortex version also helps..........can’t comment on peoples driving style but this is always a factor |
20th Nov 2012 8:54pm |
lrdaft Member Since: 08 Apr 2010 Location: United Kingdom Posts: 60 |
I get 15 to 16 on my supercharged and 19 mpg on a run ,not much in it considering petrol is about 6 p per litre cheaper 2011 4.4tdv8 vogue black with black
20th Nov 2012 9:10pm |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2618 |
Last tank used town driving only, average 18! |
20th Nov 2012 9:42pm |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 |
Round town? I get about 14, although I do like to "accelerate briskly"
20th Nov 2012 9:44pm |
Yup, all pretty short trips which didn't help! |
20th Nov 2012 9:57pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
here is a nice little fuel calculator
20th Nov 2012 10:55pm |
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1199 |
CHECK YOUR REAR CALIPERS . . . . .
20th Nov 2012 10:59pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3720 |
baldylocks, an average of around 28mpg is easily achievable with a TD6, mixed motorway and A roads, a TDV8 will do 30 ime. |
20th Nov 2012 11:10pm |
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 |
I'm getting 20 mpg out of my 4.4 V8 petrol in normal driving so you should be getting better than 18 mpg.
20th Nov 2012 11:11pm |
Aye, I had a jammed caliper, now replaced, we'll see what the next tank does, off to see fisha at the weekend so will report back. |
21st Nov 2012 8:28am |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 |
Are you driving your diesel engine like a petrol engine ? |
21st Nov 2012 11:21am |
It takes time to get used to the gearbox and get into the habit of knowning how to force it into a lockup or to stop slipping. this is the best way to yield higher MPG in the TD6 other than flushing the fuel system FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
21st Nov 2012 11:24am |
