Home > General > Boot Courtesy Lights |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6405 |
I am sure the light in the boot area (nearer the accessory socket) comes on too.
20th Nov 2012 8:33pm |
baldylocks Member Since: 05 Apr 2010 Location: Gods Own County Posts: 42 |
Thanks, yes the boot area light could well come on but it's obscured by the boot liner and dog box which sort of fill the boot quite nicely!
20th Nov 2012 8:48pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6703 |
I asked this question a while back and there was a feeling that they went off by themselves after 10 minutes (they don't on mine).
20th Nov 2012 8:51pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
In the manual it talks about a double press of the remote locki g the car with the internal sensors deactivated for when you have dogs onboard. I wonder if this would work with the boot open allowing the car to go I to sleep mode and shut off the lights? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
20th Nov 2012 8:58pm |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 |
Would something like this http://www.ventlock.com/tailgatelock.php help? It allows the car to go into sleep mode with the dog inside (you can double press to turn the alarm off). It also stops anyone from opening the rear window (although you should have a decent enough dog for that too! ).
20th Nov 2012 9:41pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16230 |
Your rear interior lights go out after a timed period (around 10 mins), then they are activated by the interior alarm sensor. Meaning, you leave your boot open unloading your shopping after 10mins the lights shut off, as you get to the rear of the car and your ultrasonic alarm sensor see's you, it turns them back on! Simples... Only problem is, the ultrasonics see your dog moving too!!! Try the double lock thing and see if that helps further? Or leave the sunroof open instead? Craig |
20th Nov 2012 10:28pm |
Craig, What happens if you want them to stay off for the entire time you have the tailgate open?
20th Nov 2012 10:48pm |
Sit on Micks boot?
20th Nov 2012 11:08pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3964 |
For information, the switch for the lights is actually part of the tailgate lock.
Another quick thought, latch the boot lid whilst its open using a screwdriver (or your key) then they may switch off?
20th Nov 2012 11:28pm |
Simple option, open sunroof up and open a window a little and close the boot? Fresh air will still get in and dog will be fine might be knackers cold inside though with all the heat escaping.
20th Nov 2012 11:47pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35114 |
according to this thread http://www.fullfatrr.com/forum/topic13473....oot+lights consensus is that they do eventually go off ... ... - .- -.
21st Nov 2012 8:57am |
