Home > General > Boot Courtesy Lights
baldylocks
United Kingdom 2004 Range Rover Vogue Td6 Bonatti Grey
I've struggled with this one today and can't find a solution to it; when I leave the dog in the dog box in the boot I open the top half of the tailgate to give her fresh air and then lock the caar with the key. Unfortunately the two lights that are set into the top tailgate stay on for as long as the tailgate is open.
I don't really want to take the bulbs out as they provide a good light when I need it but I don't want to leave the lights on for several hours when we are in and out of the car at training. Does anyone know how to isolate these lamps, there are no switches that I can see and they are the only lights that come on when the tailgate is opened?
Post #152362 20th Nov 2012 8:24pm
I am sure the light in the boot area (nearer the accessory socket) comes on too.
I haven't looked but there is either a pressure switch that shuts off when the boot closes, or the car knows from the boot open activation. The only thing you could do would be to fit switches in line with the lights and turn them on and off manually as you need to. .
Post #152365 20th Nov 2012 8:33pm
baldylocks
Thanks, yes the boot area light could well come on but it's obscured by the boot liner and dog box which sort of fill the boot quite nicely!
I did wonder about that, make a common earth for them and switch that?
Post #152371 20th Nov 2012 8:48pm
I asked this question a while back and there was a feeling that they went off by themselves after 10 minutes (they don't on mine).
It does strike me as a bit of an oversight by LR that there isn't a way of turning them off, as a lot of folks must use the tailgate open for protracted periods of time with the ingition off, so a flat battery could be the end result. Got - 2017 SDV8 Autobiography in Loire Blue
Post #152373 20th Nov 2012 8:51pm
In the manual it talks about a double press of the remote locki g the car with the internal sensors deactivated for when you have dogs onboard. I wonder if this would work with the boot open allowing the car to go I to sleep mode and shut off the lights? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #152377 20th Nov 2012 8:58pm
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
Would something like this http://www.ventlock.com/tailgatelock.php help? It allows the car to go into sleep mode with the dog inside (you can double press to turn the alarm off). It also stops anyone from opening the rear window (although you should have a decent enough dog for that too! Wink ).
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #152395 20th Nov 2012 9:41pm
Re: Boot Courtesy Lights
Your rear interior lights go out after a timed period (around 10 mins), then they are activated by the interior alarm sensor. Meaning, you leave your boot open unloading your shopping after 10mins the lights shut off, as you get to the rear of the car and your ultrasonic alarm sensor see's you, it turns them back on! Simples...
Only problem is, the ultrasonics see your dog moving too!!!
Try the double lock thing and see if that helps further? Or leave the sunroof open instead?
Craig Thumbs Up
Post #152405 20th Nov 2012 10:28pm
Craig, What happens if you want them to stay off for the entire time you have the tailgate open?
For example, if I was to attend a polo match on Micks lawn, and wanted to sit on the tailgate, quaffing some bubbly and watch proceeding without worrying that the battery will go flat........ Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #152410 20th Nov 2012 10:48pm
Sit on Micks boot?
Then yours will start when its time to have your driver take you home sir...
Craig Laughing
Post #152414 20th Nov 2012 11:08pm
For information, the switch for the lights is actually part of the tailgate lock.
You could always change the lights to leds, they could stay on all day then without affecting the battery.
Post #152415 20th Nov 2012 11:08pm
Another quick thought, latch the boot lid whilst its open using a screwdriver (or your key) then they may switch off?
Craig Thumbs Up
Post #152423 20th Nov 2012 11:28pm
Simple option, open sunroof up and open a window a little and close the boot? Fresh air will still get in and dog will be fine Smile might be knackers cold inside though with all the heat escaping.
Or leave the dog at home Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #152428 20th Nov 2012 11:47pm
according to this thread http://www.fullfatrr.com/forum/topic13473....oot+lights consensus is that they do eventually go off ... ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #152463 21st Nov 2012 8:57am
