Home > Maintenance & Mods (L322) > 2012 Rear Led Taillight fitting |
Stryke Member Since: 16 Nov 2010 Location: UK Posts: 262 |
8th Nov 2012 4:41pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
who told you that, i have fitted one of them to a 56 plate,no problem.. they use the same LCM upto 09 cars
8th Nov 2012 5:01pm |
Yes spoke with Powerful. Also they have now pulled the 05-09 kit from their range, only supplying the 02-05 kit... |
9th Nov 2012 12:02am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
They dont work on a facelift 05 onwards Dave only pre facelift...
9th Nov 2012 12:15am |
So what's the solution you have for post 05 when you're doing your conversions? |
9th Nov 2012 4:30am |
well thats the one we fitted to his car and it worked. dont know if they have long term issues as he has sold the car but never said there was any problems... V8 facelift Range Rover Autobiography 22" wheels.
9th Nov 2012 8:02am |
With all due respect sir, that's what pays the bills... Craig |
9th Nov 2012 8:04am |
Dave, powerful only supplied them for the 05> for a couple of months but had some issues i believe so withdrew then and are, as we speak working on a solution im told... Craig |
9th Nov 2012 8:49am |
Shame. You shouldn't contribute to threads if you aren't willing to help. This is where your commercial interests cause conflict. |
9th Nov 2012 1:18pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35328 |
Craigs remark was 'tongue in cheek' and he does in fact contribute a lot of advice on the forum..
9th Nov 2012 1:37pm |
Thank you Stan, saves me responding... |
9th Nov 2012 7:29pm |
mercuryf1 Member Since: 13 Jan 2009 Location: Penang Posts: 169 |
About a year ago I bought a set modules that cost £180. (including tools and full instructions.) it's on my car now and the rear lights haven't missed a beat since installation!
13th Nov 2012 8:16pm |
MarkBrand Member Since: 05 Feb 2012 Location: Belfast Posts: 39 |
So I fitted them today, got everything sorted apart from the fog light issue, which I have tried to solve with the relay idea and it worked to a point, the dash warning still exists with or without the ballist attached and the relay buzzes when the sidelights are on, but it enables you to switch the fogs on and off as normal, so i think i am close....Changing the ballist to a heavier one helps...but couldn't live with the buzz! Am I missing something?
16th Nov 2012 11:59pm |
spanner Member Since: 05 Jun 2011 Location: uk Posts: 134 |
Hi i overcame this problem using a trany BD679 and a 8v2 zener diode use the trany to feed the relay on c put a 47r resistor between trany e and 0v put 100u cap between trany b and 0v and zener between trany b and 12v jobs a good one relay will only turn on if voltage is above 10volts |
17th Nov 2012 9:35am |
