![]() | Home > Maintenance & Mods (L322) > 2012 Rear Led Taillight fitting |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
That is why there are companies like mine around to do these conversions PROPERLY!!! |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
Some like to have a go and save a few quid though and a lot like tinkering, I was an auto elec a few years ago but not tried yet as been ill a few years so works a long way off |
iansweetman Member Since: 18 May 2013 Location: wales Posts: 17 ![]() ![]() |
finallyremoving lights to have a look here's the photos the first 2 photos are the passenger light which has the sidelight no foglight on and 3rd and 4th photos show the driver side that has foglight issue and no sidelight can someone clarify which light is the correct one please!
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6773 ![]() ![]() ![]() |
Before you make your choice of interface, I realise the indicator might flash really quickly, but should the LEDs on the new light still work? I got one off the bay and plugging it in. As expected the fog light is on and when I put the indicator on, the front flashed like mad, but the rear on the new light doesn't. Got - 2017 SDV8 Autobiography in Loire Blue
andyleeds Member Since: 31 Dec 2010 Location: west yorks Posts: 968 ![]() ![]() ![]() |
so if you have an 05 AND touchscreen will they work? |
Before I throw my toys out of the pram at the flea by seller, can someone please confirm that a ROW rear led light should still indicate, albeit rapidly, without the interface box to sort this and other issues out?
As you can see I have one of each light on my vogue and only run one magic box and indicators flash normal just half fog syndrome on the one light without magic box on even if I connect second box on on the foglight stays on and box makes a buzzing noise so I leave it off. Its a brand new replacement from the seller as first one was the same, tried swapping them around onto the different lights and same outcome. |
jam220 Member Since: 08 Jun 2016 Location: Atlanta Posts: 31 ![]() ![]() ![]() |
I have a 07 Full size rover and im in the States. I am doing a front and rear conversion. I see diff post with different info. One the 07, What do i need in order to make the front and rear lights fully functional? do you sell them kits? Thank you |
hi sent you a message through your website to seeing if you have the conversion wiring front the front and rear..I have a 07 doing 2010+. Please let me know . Thanks |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35653 ![]() ![]() |
does this help?
...and rears,
Great step by step article. I have 07, it says "The lights can be plugged in as the socket is the s
PaulM Member Since: 08 Mar 2015 Location: Warwickshire Posts: 190 ![]() ![]() ![]() |
I'm thinking of doing this upgrade on my 03, will I need the interface boxes off eBay or just the resitors and fog light fix from powerful uk? 2004 RR 4.4 V8 Autobiography |
