Home > Maintenance & Mods (L322) > 2012 Rear Led Taillight fitting
Page 2 of 4 <1234>
daveo
then just go for the fog light unit from powerful uk V8 facelift Range Rover Autobiography 22" wheels.
Post #150191 8th Nov 2012 8:07am
Stryke
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Won't work with the 05+ facelift model.
Post #150237 8th Nov 2012 4:41pm
daveo
who told you that, i have fitted one of them to a 56 plate,no problem.. they use the same LCM upto 09 cars
have you spoke to powerful... V8 facelift Range Rover Autobiography 22" wheels.
Post #150242 8th Nov 2012 5:01pm
Stryke
Yes spoke with Powerful.
Also they have now pulled the 05-09 kit from their range, only supplying the 02-05 kit...
Post #150322 9th Nov 2012 12:02am
They dont work on a facelift 05 onwards Dave only pre facelift...
Craig Thumbs Up
Post #150323 9th Nov 2012 12:15am
Stryke
Craig Thumbs Up
So what's the solution you have for post 05 when you're doing your conversions?
Post #150326 9th Nov 2012 4:30am
daveo
well thats the one we fitted to his car and it worked. dont know if they have long term issues as he has sold the car but never said there was any problems... Shocked V8 facelift Range Rover Autobiography 22" wheels.
Post #150336 9th Nov 2012 8:02am
Craig Thumbs Up
With all due respect sir, that's what pays the bills...
Craig Whistle
Post #150337 9th Nov 2012 8:04am
Dave, powerful only supplied them for the 05> for a couple of months but had some issues i believe so withdrew then and are, as we speak working on a solution im told...
Craig Thumbs Up
Post #150349 9th Nov 2012 8:49am
Stryke
Craig Thumbs Up
Craig Whistle
Shame. You shouldn't contribute to threads if you aren't willing to help. This is where your commercial interests cause conflict.
Post #150394 9th Nov 2012 1:18pm
Craigs remark was 'tongue in cheek' and he does in fact contribute a lot of advice on the forum..
also consider that Craig is a site sponsor and because of that we get a forum free of ads... ... - .- -.
Post #150401 9th Nov 2012 1:37pm
Thank you Stan, saves me responding... Thumbs Up
Post #150481 9th Nov 2012 7:29pm
mercuryf1
Malaysia 2015 Range Rover SVAutobiography 5.0 SC V8 Loire Blue
About a year ago I bought a set modules that cost £180. (including tools and full instructions.) it's on my car now and the rear lights haven't missed a beat since installation!
Bought the lights from Rob. jrautoelectrics16@yahoo.co.uk '01 1.8i Freelander. Grey/ grey
'06 4.2 S/C Buckingham Blue/ Parchment
'15 5.0 S/C SVA Loire blue/ Black
Post #151118 13th Nov 2012 8:16pm
MarkBrand
United Kingdom 2005 Range Rover Vogue Td6 Java Black
So I fitted them today, got everything sorted apart from the fog light issue, which I have tried to solve with the relay idea and it worked to a point, the dash warning still exists with or without the ballist attached and the relay buzzes when the sidelights are on, but it enables you to switch the fogs on and off as normal, so i think i am close....Changing the ballist to a heavier one helps...but couldn't live with the buzz! Am I missing something?
Edit:-.... I have solved the "check fog light" warning now, so it's just the buzzing relay I need to sortout now, I understand I need to loose the 3 odd volts that exist when the sides are on, so maybe an item missing in my modification?!? A capacitor or something like that, this is not going to beat me!! 😡
Post #151636 16th Nov 2012 11:59pm
spanner
Hi i overcame this problem using a trany BD679 and a 8v2 zener diode use the trany to feed the relay on c put a 47r resistor between trany e and 0v put 100u cap between trany b and 0v and zener between trany b and 12v jobs a good one relay will only turn on if voltage is above 10volts
Post #151647 17th Nov 2012 9:35am
Page 2 of 4 <1234>
