![]() | Home > Technical (L322) > Time for FBH- what do I need to buy then? |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2943 ![]() ![]() ![]() |
I haven't got a remote, so ill need one of those. What else will I need and how can I check I haven't already got it?
Ask dan if he has time to get your build list and see if timed or remote climate is on it. If it is jobs a good en.
Hi Guys,
All it says in the menu is 'Aux Vent'. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7861 ![]() ![]() ![]() |
This is also where I'm at.....
![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
wedgel322 Member Since: 20 Jul 2011 Location: Leeds Bradford Posts: 161 ![]() ![]() ![]() |
Mine is going in to the indy today for a few things doing before winter (new tyres & brakes etc), If they can activate park heat does that mean all i need is a remote and it will work? If so does anyone know how much they are or if you can still get them? 2003 Range Rover HSE 3.0 TD6
Do you not need some Telestart thing ? Could be wrong.
Yes. Actually it will work w/o a remote as you'll be able to program 2 time presets to auto-start the park heat function. But a remote is very convenient. And it is more or less plug n play. See below.
Webasto UK (expensive) or ebay (can be quite inexpensive). Try ebay.de as well as Webasto is German and many Germans have park heaters.
You'd be someplace completely different if you'd just pony up and buy an IIDTool. That would be a real start! ![]() Sorry, couldn't resist. ![]() Copied and (re)posted from another thread http://www.fullfatrr.com/forum/post147791....eat#147791
very helpfull thank you very much indeed. Im off to garage now so i will post back how i get on. 2003 Range Rover HSE 3.0 TD6
I've seen a telestart T91.remote on eBay- are they compatible with early L322s like mine? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
And 2nd question- do the VW units work in a FF as there are loads for sale on eBay. They look the same 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
The plugs for the wiring harnesses are different. Compare the white socket on the T60 receiver in the top pic to the black on the lower. The T80/90 had a rectangular plug. The T60 a nearly square plug. Also certain series of the later receivers emitted a W-bus signal to start the heater rather than a simple +12V signal which you need. Just get a T60 receiver/sender set and be done with it, Noddy. Plug and play. Buy on ebay.de with a seller who accepts paypal if you can't find one in the UK. They are much more plentiful and are likely to be much less expensive. ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
