Home > Maintenance & Mods (L322) > Still knocking! |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
Without taking the .... Could the noise be coming from the right hand side????
12th Nov 2012 6:57pm |
rads Member Since: 04 Sep 2011 Location: Herts Posts: 157 |
Mine is still knocking too, but I'm pretty convinced it is the gearbox sub frame.
12th Nov 2012 7:00pm |
Glideman Member Since: 11 Sep 2011 Location: Stood next to a broken down Range Rover in Darwen Posts: 112 |
Yes to all, I've had it to the main agents 4 times & they don't know what it is, they did however part me with £3000 trying to find it. I've also had it to several independents who also can't find it. It's gone through an MOT to. Range Rover 4.4 V8 Vogue |
Contraband could be right, noises in cars can be extremely hard to pinpoint to the location. Also if one side has wonky rubbers, the other side usually has the same issue (did on mine S/C, so both sides now have new rubbers). MY 2010 5.0 SC Galway green and sand interior!!
Edited my first post Previously..
12th Nov 2012 7:03pm |
Hi David, sorry you've not sorted yours either, can't understand why even the main agents don't know how to fix these cars. I remember you saying it must be the steering rack last time I mentioned it, how did that pan out Range Rover 4.4 V8 Vogue |
12th Nov 2012 7:04pm |
Changed inner track rod ends - no improvement.
12th Nov 2012 7:18pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7818 |
Lower ball joint fixed mine. Had previously had new anti-roll bar and ar bar drop links, but made no difference.
12th Nov 2012 7:34pm |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 |
Mine knocks too, always has, done all the lower joints and drop links.
12th Nov 2012 9:02pm |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 |
My X5 used to knock when driving at 45 degrees off of the drive (if you see what i mean) turned out to be the steering rack mounts needed nipping up. Took months and many visits to sort that one........... |
13th Nov 2012 9:01am |
DeRanged Rover Member Since: 16 Feb 2012 Location: London Posts: 379 |
I'vce had the knock too ... been to three separate garages, replaced drop links and been subjected to much poking and prodding (the car, not Me!) and no result.
13th Nov 2012 3:17pm |
I know this is easy for me to say, but, all of you.. You either have something worn or loose. Your mechanics are letting you down. They should not eventually find out what it is, they should find it first time if they are any good. Previously..
13th Nov 2012 4:56pm |
I suppose I'd better give myself a strong talking to, don a horsehair shirt and flagellate myself with birch twigs. That'll learn me.
I'll then get on with following up your most remarkably perceptive suggestion. David |
14th Nov 2012 9:09am |
Contraband's point was sort of my point, in that joints and stuff will look OK when checked by a mechanic with a bar "in the normal way", but as the car is so heavy, any wear will result in a knock. Unless a mechanic has had experience of going through, changing tons of items to find what it is, they will be a bit stuck.
14th Nov 2012 9:21am |
