Home > Maintenance & Mods (L322) > Still knocking!
Glideman
Location: Stood next to a broken down Range Rover in Darwen
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Still knocking!
I've replaced just about every part on the left hand suspension leg to try to stop a knocking noise on the passenger side of my RR. Not many more things I could try but I was wondering if it may be caused by an imbalance in the suspension air bags? The reason I ask is I seem to remember reading something about the suspension needing calibration?
I've replaced
left front suspension leg (new Dunlop)
both front drop link arms
suspension lower leg
both sides rear suspension bushes top & bottom
both front wheels
front brake pads
water pump & viscous fan
IT's STILL BLOODY KNOCKING!!! Big Cry Range Rover 4.4 V8 Vogue
Post #150917 12th Nov 2012 7:53pm
Without taking the Censored .... Could the noise be coming from the right hand side????
Is the anti roll bar tight? Is the tray underneath the front tight?
My knocking noise was the lower control arm ball joint. When I replaced it, the ball joint was tight, but the other end with the large rubber bush, I thought it was tight enough but the bush was slightly smaller than the original one and I had just locked the bolt up against the bracket, so the bush was loose and knocking. Previously..
Post #150918 12th Nov 2012 7:57pm
rads
2005 Range Rover Vogue SE Supercharged Tonga Green
Mine is still knocking too, but I'm pretty convinced it is the gearbox sub frame.
Get a rubber mallet (or a block of wood!) and whack around the subframe mounts. One of mine sounds definitely more metallic than the rest.
If I ever get any free time, I'll try something cunning with some thick rubber sheet before forking out for a new sub-frame. Bushes are not available as a separate item!
David
Post #150919 12th Nov 2012 8:00pm
Glideman
Yes to all, I've had it to the main agents 4 times & they don't know what it is, they did however part me with �3000 trying to find it. I've also had it to several independents who also can't find it. It's gone through an MOT to. Range Rover 4.4 V8 Vogue
Post #150920 12th Nov 2012 8:00pm
ebajema
Contraband could be right, noises in cars can be extremely hard to pinpoint to the location. Also if one side has wonky rubbers, the other side usually has the same issue (did on mine S/C, so both sides now have new rubbers). MY 2010 5.0 SC Galway green and sand interior!!
Post #150922 12th Nov 2012 8:00pm
Edited my first post Previously..
Post #150923 12th Nov 2012 8:03pm
Glideman
Hi David, sorry you've not sorted yours either, can't understand why even the main agents don't know how to fix these cars. I remember you saying it must be the steering rack last time I mentioned it, how did that pan out Whistle Range Rover 4.4 V8 Vogue
Post #150924 12th Nov 2012 8:04pm
rads
Changed inner track rod ends - no improvement.
Decided against changing the rack as
1) Too difficult
2) Too expensive
3) Was hoping you would do it first
Anyway, go and thump your sub-frame mounts and report back!
Very Happy
David
Post #150926 12th Nov 2012 8:18pm
mjdronfield
Lower ball joint fixed mine. Had previously had new anti-roll bar and ar bar drop links, but made no difference.
I believe these motors are heavy, and you may bang around underneath with a screw driver or a pry bar, and a joint etc can look OK, but the car still makes it knock out on the road.
If you see what I mean.
Not much help I know, but just because a garage puts it on a ramp, and prods the suspension to look for wear, they still might not see it.
Good luck. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #150929 12th Nov 2012 8:34pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Mine knocks too, always has, done all the lower joints and drop links.
Read the BMW X5 forums, they have the same problem.
Post #150938 12th Nov 2012 10:02pm
T24RES
My X5 used to knock when driving at 45 degrees off of the drive (if you see what i mean) turned out to be the steering rack mounts needed nipping up. Took months and many visits to sort that one........... Whistle
Post #150996 13th Nov 2012 10:01am
DeRanged Rover
United Kingdom 2006 Range Rover Vogue SE Td6 Java Black
I'vce had the knock too ... been to three separate garages, replaced drop links and been subjected to much poking and prodding (the car, not Me!) and no result.
I have just started turning the music up loud! Sad African Bush Junkie ... in London!
Stats:
2006 TD6 Vogue SE
1972-2015 DeRanged Rover
2001 P38 dHSE (SOLD)
Post #151075 13th Nov 2012 4:17pm
I know this is easy for me to say, but, all of you.. You either have something worn or loose. Your mechanics are letting you down. They should not eventually find out what it is, they should find it first time if they are any good. Rolling Eyes Previously..
Post #151080 13th Nov 2012 5:56pm
rads
I suppose I'd better give myself a strong talking to, don a horsehair shirt and flagellate myself with birch twigs.
That'll learn me.
I'll then get on with following up your most remarkably perceptive suggestion.
Wink
David
Post #151179 14th Nov 2012 10:09am
mjdronfield
Contraband's point was sort of my point, in that joints and stuff will look OK when checked by a mechanic with a bar "in the normal way", but as the car is so heavy, any wear will result in a knock. Unless a mechanic has had experience of going through, changing tons of items to find what it is, they will be a bit stuck.
Items that initially may appear OK, actually may not be...........
Garange changed a few bits on mine, and then changed something they thought was OK, as they'd done everything else...... problem solved. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #151182 14th Nov 2012 10:21am
