Home > Maintenance & Mods (L322) > Still knocking!
BRING THEM ALL TO ME!
Have had this many many times with different customers telling me "oh, we've been to 5 different places over a period of a year or more" and your the first to fix it...
Baffles me how most of these people are still in business...
Craig Whistle
Post #151187 14th Nov 2012 10:31am
rads
2005 Range Rover Vogue SE Supercharged Tonga Green
So, how confident are you?
I'd bring it to you on the basis that:
1) You only change one bit at a time. Any bits you fit, and time taken to fit them, that don't fix the problem are down to you.
2) You pay my time and travel expenses if you fail to find a cure.
Still want to have a go?
Wink
David
Post #151202 14th Nov 2012 11:07am
Glideman
Location: Stood next to a broken down Range Rover in Darwen
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
I'm 420 miles away & getting 17-18 MPG Very Happy Range Rover 4.4 V8 Vogue
Post #151231 14th Nov 2012 3:04pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
I'd pay over the odds to get mine fixed, the knocking is driving me nuts!!
Post #151233 14th Nov 2012 3:14pm
mjdronfield
Sounds like you need a visit to Craigs.
Are you both not in Gloucestershire ?
Sounds like a plan to me.........
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #151235 14th Nov 2012 3:34pm
vnitos
South Africa 2016 Range Rover SVAutobiography 5.0 SC V8 Baltic Blue
had the same problem - replaced ball joints, suspension links, etc - without solving the problem.
advice i got from this forum was to loosen and tighten the suspension with all 4 wheels on the ground - the indie replaced the parts above with the wheels hanging (car was on a lift). however it only lasted for a few months.
a few weeks ago i took it to the same indie - this time they loosened the subframe and i dont know what all - amazingly the knock is still gone
car drive like a totally different car - suspension feels tighter - one actually now has the confidence to throw it into corners at much higher speeds than before - previously one was not always sure if the car would turn the way you want it to or not
so, before you spend anymore money, do the above and check it then - indie actually confirmed that i spent unnecessary money when the parts listed above were replaced
Post #151238 14th Nov 2012 3:54pm
PM's sent rads & Richcl
Craig Thumbs Up
Post #151278 14th Nov 2012 9:34pm
D8DEL
Scotland 2006 Range Rover Vogue Td6 Bonatti Grey
L322 steering rack.
Alright guys, just been reading about the knocking coming from the front of your L322's.
I've got the same with mine and once I'd got into the guts of her, noticed play in the actual rack itself.
The rack ends are fine as are all my ball joints, rubbers and links. It's coming from the O/S right at what looks like an adjuster to the front of the car.
Does anyone know if this can be adjusted or tightened to stop the inners of the rack moving around inside the casing?.
Cheers for your help and I hope this might help solve a few mysterious knocks.
Post #281604 17th Sep 2014 7:29pm
Glideman
Got a picture of it or an exact part ref? Range Rover 4.4 V8 Vogue
Post #281632 17th Sep 2014 9:37pm
D8DEL
Sorry mate, didn't think to take pictures.
I found it when I asked a friend to rock the steering for me and noticed the steering rack end had quite a bit of movement.
I obviously thought it was the replaceable end that was gubbed so I took the protective plastic boot off the assess the job in hand. No play in the ball end at all but plenty movement in the toothed shaft that moves in and out the rack to steer the car. It had up n down movement which seemed to be causing the knocking noise, pretty much like a knacked ball joint etc. Built it back up now to get me back on the road, not sure if the rack can be tightened in any way or if it needs to be replaced.
Post #281638 17th Sep 2014 10:37pm
